I would like some help.
I’m having trouble with a semaphored,
Why is semaphoro blocking the resource? Why isn’t he releasing the resource with give ?
void v_AlarmeTempLed(void *parameters) {
float tempReceived;
//TaskHandle_t Handle_PiscaLed = NULL;
while (1) {
if (xQueueReceive(TempC_Queue, &tempReceived, portMAX_DELAY) == pdPASS) {
if (tempReceived < alarme.Inicio || tempReceived > alarme.Fim) {
if (Handle_PiscaLed == NULL) {
Serial.println("Entrei na criação da tarefa...");
xTaskCreate(v_PiscaLed, "v_PiscaLed", 4096, NULL, tskIDLE_PRIORITY + 1, &Handle_PiscaLed);
} else if (tempReceived >= alarme.Inicio && tempReceived <= alarme.Fim) {
Serial.println("Temperatura Correta");
if (Handle_PiscaLed != NULL) {
if (xSemaphoreTake(xMutexLed, portMAX_DELAY)) {
Serial.println("Vou deletar a tarefa....");
LigaLed(2,false);
vTaskDelete(Handle_PiscaLed);
Handle_PiscaLed = NULL; // Redefinir o identificador
xSemaphoreGive(xMutexLed);
vTaskDelay(1500 / portTICK_PERIOD_MS);
void v_PiscaLed(void *parameters){
while(1){
if (xSemaphoreTake(xMutexLed, 100)) {
digitalWrite(Led1, HIGH);
vTaskDelay(500 / portTICK_PERIOD_MS);
digitalWrite(Led1, LOW);
Serial.print(".");
the impression I have is that give does not work for the other task to release processing.
Where am I going wrong?
He took a long time to be released, what must be happening?
