for (;;) {
xSemaphoreTake(XSemSend, portMAX_DELAY);
// doing some consuming process
in few other tasks during the consuming process of task1 I can have xSemaphoreGive (XsemSend); let’s say 6 times. I discovered that when the consuming process is done and it goes to SemaphoreTake waiting it immediately going again to consuming process, but only no more than 3 times, is this normal or not?
Sorry - I don’t understand your question. Are you saying that if you
give a semaphore 6 times you would expect to be able to take it 6 times
too? That would only be the case if the semaphore was created as a
counting semaphore with the max count parameter set to 6 or greater.
