I was wondering if a change could be implemented to accommodate Trust&Go ATECC608A_TNGTLS secure element certificates in FreeRTOS. I am using an ESP32-WROVER devkit connected to an ATECC608A_TNGTLS secure element from Microchip.
The FreeRTOS version is 202007.00 and my host machine is a Windows 10 PC. My problem is that after building with the command cmake -DVENDOR=espressif -DBOARD=esp32_plus_ecc608a_devkitc -DCOMPILER=xtensa-esp32 -DCMAKE_BUILD_TYPE=Debug -GNinja -S . -B build
to specify that I am using the ATECC608A_TNGTLS for the TLS connection, the default device and signer certificates definitions being used cause an ATCACERT_E_WRONG_CERT_DEF error when reading the certificates from the ATECC608A_TNGTLS .
I changed the default device certificates being assigned here and here to tng22_cert_def_2_device and tng22_cert_def_1_signer respectively which are defined in \vendors\microchip\secure_elements\app\tng\ directory. That fixed the error and I was able to properly read off the certificates from the ATECC608A_TNGTLS. Can a switch or build option be built into freertos to accommodate the different ATECC608A types (Trust&Go, TrustFlex, Trust Custom)? I assume that is the discrepancy between the default certificate not working and the tng22 types working for my ATECC608A_TNGTLS.
