Hi Guys,
I have 4 tasks and all the tasks are of equal priority. Each task increments its respective counter and performs yield.
void thread_0(void)
while(1)
taskYIELD();
/* Increment this thread's counter. */
thread_0_counter++;
Similar to this all other tasks are created with their respective counters. The variables are global and configUSE_PREEMPTION is set to 1.
The goal of the application is to see whether the tasks are performing cooperatively.
when I set a breakpoint after 2s(arbitrary), my expected output is that all the counters should have the same value. but I am seeing a difference in the counter values.
if configUSE_PREEMPTION is set to 0 and the application is run, my expected behaviour is happening. ie. the counter values are same.
I understand that configUSE_PREEMPTION set to 0 causes cooperative scheduling which inturn is giving my expected result, but Why is configUSE_PREEMPTION set to 1 (priority preemptive scheduling) with equal priority tasks, not giving the same result? what is happening internally? kindly explain this behaviour.
