we need to execute all FreeRTOS functionality from FreeRTOS ( mainly heap memory )
But I have some basic doubts regarding context switching while communicating with External HyperRAM as follows:
as per datasheet of hyperRAM , (S70KL1281 section 3.2Command/Address Bit Assignments ) , it takes several clock cycles to start data transfer .
most importantly data bus of HyperRAM is of 8 bit & RTOS functionality is considering 32 bit ( as MCU is 32 bit ) . So data communication might not be ‘atomic’ .
So what will happen if context switching happens during operation ? how to prevent external HyperRAM data corruption ?
I am not familiar with that particular combination, but here are my general observations:
The datasheet says that the processor make the external memory look like internal memory, so that means that at the processor level, a request from the chip will processed a pull a bit from that memory into a local cache, transparently to the program.
First, this means that you don’t need to worry about switching in the middle of a operation, the processor will handle the details itself.
It does mean that you will get a slightly increased latency, as such a request will stall the processor (just like a request to other external memories, or sometimes even internal flash). Unless you have nano-second level latency requirements this probably isn’t a concern.
Also, you don’t need to worry about the device being ‘8 bits’, the processor will grab enough data to do the operation.
