nobody wrote on Saturday, April 29, 2006:
Has anyone tried to build FreeRTOS with Crossworks 1.6?
Version 1.6 now has good support for AT91SAM7X and the SAM-ICE but so far I get memory exceptions during mem_init when creating semaphores.
V1.5 is still showing as the latest version on the Rowley site. I will request an upgrade so I can take a look.
rtel wrote on Thursday, May 11, 2006:
[I have excluded the original message as it contained an email address. This repost is identical with the email address clobbered. Please do not post email addresses in plain text.]
I have just been given the V1.6 as an eval - try mpj____@____rowley_._co#.#uk (Michael Johnson).
Off topic: I’ve just tried the web deom for the SAM7X and seem to have no vector table - when the initial process hits the first context switch - bang. Anyone found this before ?
Are you using V1.6? If so then as per this thread it is known not to work yet. You should not find the same problem in V1.5 which is being used by a lot of people. Hopefully support for V1.6 will be added very shortly.
nobody wrote on Friday, May 12, 2006:
Sorry about the eMail address - stupid, really
I was using V1.6 as Rowley suggested it for supporting the SAM7X devices - Have I been lead away from the true path?
An added complication may be - I’m using a Segger Jlink.
The question I asked Rowley was how to build a product template for the 7X chip, as its Flash & Ram layout is different - at least bigger. I was pointed at the freeRTOS/BasicWEB demo. Does anyone else have a V1.5/SAM7X setup ?
Oh, I,m Dave Kitchen by the way
rtel wrote on Friday, May 12, 2006:
Sorry, I’m a bit confused. You ask “Does anyone else have a V1.5/SAM7X setup?”, does this mean you cannot get the SAM7X demo to work with V1.5? It should compile and execute exactly as downloaded.
If you have having problems with V1.5 can you say whether you have made any changes, and if not explain more about what the issue is. Thanks.
I understand from Rowley that the V1.6 version provides better support for the SAM7X chips, but I have not tried it yet. The demo will be updated for V1.6 eventually.
