inimicus8 wrote on Monday, September 21, 2015:
Hi I have a problem that it takes a long time to resume a task when i call ”xTaskResumeFromISR” from within a interrupt. It takes at least 7ms from that I call ”xTaskResumeFromISR” to that the task starts executing. The delay time slowly increases to over 100ms.
If i call vTaskResume from another task the task resumes immediately. I only have one interrupt on and only one other task that only contains a while loop and vTaskDelay(100/portTICK_RATE_MS);. (if I don’t have another task I can’t run the program for some reason)
program:
main:
xTaskCreate( taskB, ( signed char * ) “taskB”, configMINIMAL_STACK_SIZE, NULL, 2, NULL );
xTaskCreate( CAN_Control_Task, ( signed char * ) “C_Control”, configMINIMAL_STACK_SIZE, NULL, 1, &canHandle );
// FreeRTOS start
vTaskStartScheduler();
void CAN_Control_Task( void* pdata )
CAN_Config();
while (1)
CAN_ReceiveRoutine();
vTaskSuspend( NULL );
// ulTaskNotifyTake( pdTRUE, (10000/portTICK_RATE_MS) );
void CAN_RX_Interrupt( void )
BaseType_t xHigherPriorityTaskWoken = pdTRUE;
IO_OkStatusLedOn();
if (CAN_GetITStatus(CANx, CAN_IT_FMP0) != RESET)
xTaskResumeFromISR( canHandle );
// vTaskNotifyGiveFromISR( canHandle , &xHigherPriorityTaskWoken );
CAN_ClearITPendingBit(CANx, CAN_IT_FMP0);
Does anyone know why this happens and how to fix it?
Same thing happens when I use “ulTaskNotifyTake” and “vTaskNotifyGiveFromISR”
When I run my program In CoOS I don’t get this problem.
Info about platform: MCU: stm32f407: IDE: coocox 2.0.3. toolchain: gcc 4.8 2004. RTOS: FreeRTOS V8.2.2
