I am running FreeRTOS v8.2.0 with FreeRTOS+FAT SL on Atmel Cortex M4 SAM4SD16C. I am using Atmel Studio for my project. Recently I have noticed that if I change the optimization level in Atmel Studio to None(-O0) from Optimize(-O1) the FreeRTOS+FAT SL is unable to open a file on SD card. However, If I use Optimize (-O1) the file system can access the file on SD card without any problem. Is there some recommendation for optimization level in Atmel Studio while useg FreeRTOS+FAT SL or FreeRTOS in general? Has anyone experienced this issue before? Please do share.
I have never noticed this before. It should work at all optimisation
levels, but if there is ever a problem it is normally the other way
around - things working with no optimisation but failing at high
optimisation.
As it is low optimisation that is causing the problem could it be a
stack issue? Low optimisation will presumably use more stack. Do you
have stack checking turned on?
Which driver are you using? SD card driver from the ASF?
Can you step through the code to see where it fails? It might be in the
FAT code itself, or possibly in the driver.
I am using the FreeRTOS+FAT FS so the file system is designed for RAM but I have modified it to work with SD card by providing read and write low level functions. i am not sure how to do the stack checking if you could please guide me in this regard. Also the problem does not occur while initializing the SD card which is the following part
void vInitializeSDCard( void )
unsigned char ucStatus;
//! Initialize the SD card and create the volume
//! @code
ucStatus = f_initvolume( sd_init );
//! @endcode
// It is expected that the volume is not formatted.
if( ucStatus == F_ERR_NOTFORMATTED )
//! Format the created volume with FAT32 FS.
//! @code
ucStatus = f_format( F_FAT32_MEDIA );
//! @endcode
if( ucStatus == F_NO_ERROR )
pstring("SD card initialized");
else if( ucStatus != F_NO_ERROR )
printf("Error No. %d occurred in SD Card initialization\r\n", ucStatus);
after this I try to open a file on my SD card which in case of optimization level (-O1) opens successfully whereas in case of optimization set to None(-O0) the following call returns a NULL
pxFile = f_open( cFileName, “r” );
I believe there is something I am missing. If so, please do let me know.
Can you step through the f_open() call to see if it gives a clue as to
why it is not happy - that might give a clue as to what went wrong with
the initialisation (mounting, formatting, etc.). With optimisation 0 it
should be easy to step through.
One more thing I should mention is that I am accessing the file before the scheduler is started and once I run it on optimization level 1 it is running without any problem until i change the optimization to None and rebuild the project. Note that if i change optimization to None from Level 1 and without rebuilding the solution directly start the project it also runs.
That being said i have stepped into the code and found out that the function
