Receiving a GetLastError() 87 while using a queue
I’m new to using FreeRTOS. I’m doing a course on it and I’ve been given a problem where I need to pass a (double**)c to the queue and then have another task receive it and print it.
I’m receiving an error. It says
ASSERT! Line 1246, file D:\FreeRTOS\FreeRTOSv10.0.1\FreeRTOS\Source\queue.c, GetLastError() 87
I’m unable to understand where am I going wrong. Would be great if you guys could point out my mistake or guide me in the right direction.
Here are the relevant code snippets
xQueueHandle Queue1;
static void matrix()
double** c = (double**)pvPortMalloc(ROW * sizeof(double*));
	for (i = 0; i < ROW; i++) c[i] = (double*)pvPortMalloc(COL * sizeof(double)); /*creating a matrix */
if (Queue1 != 0) /* the if construct is inside an infinite while loop and inside the loop the contents of the matrix change*/
			xQueueSend(Queue1, (double**)c,1000);
		vTaskDelay(100);
static void reader_task() /*continuously reading the data from the queue and printing it*/
	while (1)
		printf("Reader Task has started\n");
		double** variable = (double**)pvPortMalloc(ROW * sizeof(double*));
                for (int i = 0; i < ROW; i++) variable[i] = (double*)pvPortMalloc(COL * sizeof(double));
		xQueueReceive(Queue1, &variable, 500);
		printf("Check\n");
		for (int i = 0; i < SIZE; i++)
			for (int j = 0; j < SIZE; j++)
				printf("%f", variable[i][j]);
			printf("\n");
int main()
	Queue1 = xQueueCreate(100, sizeof(double**));
	printf("Queue created\n");
Looks like in your main you’re declaring an xQueueHandle Queue1 which is hiding the global one.
Now I would reduce the example even further and remove the pvPortMalloc and have a local variable instead. As I can’t see any pvPortFree in the provided code I can only assume that you’re running out of memory.
I overlooked it. I rectified it and the program works. Thanks for your help.
