jeronimo479 wrote on Tuesday, May 29, 2018:
Example for a Readers/Writer Lock:
struct ReadWriteLock_struct
SemaphoreHandle_t xSem;
SemaphoreHandle_t xMutex;
uint32_t max_readers;
} ReadWriteLock;
typedef struct ReadWriteLock_struct *ReadWriteLock_t;
ReadWriteLock_t rwlock;
void RWLock_readers_take(ReadWriteLock_t rwlock)
xSemaphoreTake(rwlock->xSem, portMAX_DELAY);
void RWLock_readers_give(ReadWriteLock_t rwlock)
xSemaphoreGive(rwlock->xSem);
void RWLock_writer_take(ReadWriteLock_t rwlock)
uint_fast8_t count;
xSemaphoreTake(rwlock->xMutex, portMAX_DELAY);
for(count = 0; count < rwlock->max_readers; count++)
void RWLock_writer_give(ReadWriteLock_t rwlock)
uint_fast8_t count;
for (count=0; count < rwlock->max_readers; count++)
xSemaphoreGive(rwlock->xMutex);
void main(void)
rwlock = (ReadWriteLock_t)pvPortMalloc(sizeof(struct ReadWriteLock_struct));
rwlock->xSem = xSemaphoreCreateCounting(4);
rwlock->xMutex = xSemaphoreCreateMutex();
vPortFree(rwlock->xMutex);
vPortFree(rwlock->xSem);
vPortFree(rwlock);
Previously I posted this because I thought I had trouble with a recursive xSemaphoreTake() call. I was mistaken. I had grouped the components into a struct, then only allocated the size of a pointer, not the size of the struct to rwlock:
—BAD CODE—> rwlock = (ReadWriteLock_t)pvPortMalloc(sizeof(ReadWriteLock_t))
So the problem wasn’t with repeated calls to xSemaphoreTake(), but with the improper allocation or rwlock.
I hope this helps others.
Wayne
