frnyb wrote on Saturday, April 06, 2019:
I admit being a newbie in the realm of FreeRTOS, but at this point I have spent many, many hours and I therefore now turn to this forum. I appoligise in advance if I have missed something completely obvious.
I am using Code Composer Studio as IDE, GCC compiler, Tiva C Launchpad development kit with MCU ARM tm4c123gh6pm. (though he MCU is irrelevant as I haven’t tried to flash yet, only build).
FreeRTOS v. 10.2.0
As my FreeRTOS project was bugging a lot, I decided to set up a raw project containing only the FreeRTOS source code, the FreeRTOSConfig.h and my main.c along with all other files created when creating a new project.
I have directories listed as include paths:
FreeRTOS\Source
FreeRTOS\Source\include
FreeRTOS\Source\portable\GCC\ARM_CM4F
When testing functionality of each FreeRTOS module, I get stuck already at task creation. With slight modification I’m using the example code for method xTaskCreate. My main.c:
#include "FreeRTOS.h"
#include "task.h"
/* Task to be created. */
void vTaskCode( void * pvParameters )
/* The parameter value is expected to be 1 as 1 is passed in the
pvParameters value in the call to xTaskCreate() below.
configASSERT( ( ( uint32_t ) pvParameters ) == 1 );*/
for( ;; )
/* Task code goes here. */
/* Function that creates a task. */
int main( void )
BaseType_t xReturned;
TaskHandle_t xHandle = NULL;
/* Create the task, storing the handle. */
xReturned = xTaskCreate(
vTaskCode, /* Function that implements the task. */
"NAME", /* Text name for the task. */
1, /* Stack size in words, not bytes. */
( void * ) 1, /* Parameter passed into the task. */
tskIDLE_PRIORITY,/* Priority at which the task is created. */
&xHandle ); /* Used to pass out the created task's handle. */
if( xReturned == pdPASS )
/* The task was created. Use the task's handle to delete the task. */
vTaskDelete( xHandle );
while(1) { }
return 0;
The error I get is similar to the errors I get when testing other FreeRTOS functionality:
undefined reference to ‘vTaskDelete’
undefined reference to ‘xTaskCreate’
I haven’t modified the source code or directory structure at all. I’m completely at loss. Does anybody have any suggestions? Anything would be much appreciated!
