I am attempting to track down a RAM corruption issue.
Project Info:
Processor: STM32F103VE (Coretx M3)
Tools: ARM RVDS 4.0 SP3
Free RTOS V6.0.4
Using Portability Functions: RVDS->ARM_CM3
It appears that the Main Stack Pointer (MSP) is being corrupted when the RTOS is starting up. I traced it down to a function that sets the MSP. The function is called vPortStartFirstTask. On completion of this function the MSP is pointing directly in the middle of an array that I have defined to hold some data for my LCD. This is causing the LCD data to become corrupted.
Normally cortex m3 chips will define a stack either as a simple array or by reserving space using the linker script. In either case the first position in the vector table should be set to point to the stack. Is this the case in your application?
Is the linker script reserving space for your LCD buffer, or is that just using C variables?
I put a break point at the entry point my my main function and then looked vector table as you suggested. It apears that the SP address that is located in the vector table is not correct.
I am using a static C varaiable to hold the LCD data.
I agree that it looks like a linker issue. I think I may be missing something my the linker directive file (scatter file) or in the project settings. The project is not bassed on the demo in the Free RTOS zip file. I didn’t think there was a demo for ARM RVDS. I though that only CM3 ones were for MDK.
As I reported on 15.12.2009, “Potential stack problem on STM32”, there are use cases where the _actual_ stack pointer will have to differ from the _initial_ stack pointer given in the vector table.
The STM3210E Eval board features external memory, and the ST provided startup-code will move the stack pointer to that memory after initializing the FSMC (flexible static memory) controller.
After looking at this some more , my MAP file generated by the linker is telling me that the Stack is located at: 0x20008128 with a length of 0x2000
0x20002128 0x00006000 Zero RW 69 HEAP startup_stm32f10x_hd.o
0x20008128 0x00002000 Zero RW 68 STACK startup_stm32f10x_hd.o
The first entry in the vector table doesn’t match this value.
This appears to be because the startup_stm32f10x_hd.s file defines the __initial_spTop EQU 0x20000400
This value is then used in the Vectors section:
__Vectors DCD __initial_spTop ; Top of Stack
DCD Reset_Handler ; Reset Handler
DCD NMI_Handler ; NMI Handler
On entry to main () the MSP register value is equal to 0x2000A110. Which looks like an okay address for the stack based on the stack starting at 0x20008128 with a length of 0x2000.
I think the problem, as tomask mentioned, is that the FreeRTOS code is initializing the MSP using what is in the vector section.
I could introduce something for all Cortex-M3 ports whereby the address of the stack to use after the scheduler is started is set using a #define. If the define exists then the address is used, if the define does not exist then the address from the vector table is used.
Looks like switching to the new file solves the problem.
I am not sure why you would want to place the stack in xram as it is normally slower. Especally on this target. Maybe the were using the intrenal ram for a video buffer and wanted that buffer to have the fastest possible access.
