From experience of answering this question, I would say it is almost certain that you have your interrupt priorities and configuration set incorrectly.
See the documentation page for the port you are using, the descriptions of configKERNEL_INTERRUPT_PRIORITY and configMAX_SYSCALL_INTERRUPT_PRIORITY in the customisation section of the web site and in the Cortex-M3 edition of the FreeRTOS tutorial book, and item three here: http://www.freertos.org/FAQHelp.html
For your information… our application has the kernel & Max_Syscall priority as follows: #define configKERNEL_INTERRUPT_PRIORITY 255 #define configMAX_SYSCALL_INTERRUPT_PRIORITY 191
And i am using two interrupt service routine, which has the interrupt priority level set to 192 & 193 respectively for ISR1 & ISR2. These two ISRs will call “FromISR” API.
But with the above priority settings, still i see the crash is happening at the infinite for loop
for( pxIterator = ( xListItem * ) &( pxList->xListEnd ); pxIterator->pxNext->xItemValue <= xValueOfInsertion; pxIterator = pxIterator->pxNext )
Can you please tell me whether the above ISRs interrupt priority is proper or not.?
I am using STM32 microcontroller(Medium density VL) for our project and
For the 1st ISR,
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 192;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
for the 2nd ISR,
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 193;
This is how the pre-emption priority & sub priority were initialized in our project.
Do you call NVIC_PriorityGroupConfig( NVIC_PriorityGroup_4 ) in your set up routine. That sets how many bits are used for each before you set actual interrupts like in your code. As well, there are only 4 upper bits so 192 and 193 will end with the same priority.
Just to chime in … I’ve gotten stuck here before when using FreeRTOS v6.1.0 on an RX62N. The reason for being stuck in the infinite loop here was there one of my tasks was not allocated enough stack space.
You might want to check the memory map of your Task just in case.
