I am trying to use a qeueu to get data from an interrupt to a task.
The interrupt is trigged by the UART. I receive a character there and send it with a queue to a task. The task should evaluate what character it received and according to that should light a led.
In the same task I also have a function that will send back the character that the microcontroller received just to test if the queue was working. I receive the character on my serial monitor no problem. The problem is I start receiving the same character over and over again even if I don’t send any new characters. I don’t really understand why this is happening, because when I used queues before the same way this never happened. Can anyone please explain this behaviour to me?
UART1PutChar() will be called with the last character for every loop regardless of an item in the queue. Before your first letter received, it will output whatever is in string_received at initialization.
That is fine for low bandwidth comms, such as receiving key presses, but
very inefficient for high bandwidth comms where a circular buffer or DMA
is better.
If you receive only one character then this code will print out that
character every 1000 ticks. That is because you have the queue receive
timeout set to 1000, and print the character stored in string_received
whether a new value was received on the queue or not. Moving the
UART1PutChar() call inside the if() statement would fix that.
I’m guessing this is a PIC32? Please read the documentation page for
this port as the way you are defining your interrupt is going to waste a
lot of RAM (although it will work).
xQueueSend(UART_queue , &data_in , 1000); // send data via queue
This was all I found, but i’m not sure what I should be looking for in here. I don’t know any alternative ways of declaring an interrupt handler. Is this only a FreeRTOS concern or if I weren’t using FreeRTOS this declaration would still be bad?
In the dspic demo project in serial.c this is how interrupts are defined, they are the same as mine:
void __attribute__((__interrupt__, auto_psv)) _U2RXInterrupt( void )
char cChar;
portBASE_TYPE xHigherPriorityTaskWoken = pdFALSE;
/* Get the character and post it on the queue of Rxed characters.
If the post causes a task to wake force a context switch as the woken task
may have a higher priority than the task we have interrupted. */
IFS1bits.U2RXIF = serCLEAR_FLAG;
while( U2STAbits.URXDA )
cChar = U2RXREG;
xQueueSendFromISR( xRxedChars, &cChar, &xHigherPriorityTaskWoken );
if( xHigherPriorityTaskWoken != pdFALSE )
taskYIELD();
