While testing the message queue, I tried to set the queue size of 0 in QueueCreate API.
In that case,
a) queue creation was successful.
b) sending the data and receiving the data also successful.After received the data, I checked the xQueueReceive result. xQueueReceive returns pass.
Are we allowing the user to create the queue item size as 0 bytes or initmating the user with error?.
Queue item sizes of 0 are used in the implementation of semaphores, so they don’t report that option as an error, but I can’t see any use for it (other than making the Queue act like a semaphore)
As you have posted several questions on the theme of failure cases, and
I’m not sure how many more you are going to post, I strongly encourage
you to look at and step through the source code to quickly and easily
find the answers to questions such as “what happens if I create a queue
of of size 0” - much faster than posting here and waiting for an answer.
Hi Richard, thanks for the response. Queue item sizes of 0 are used in the implementation of semaphores,
I doesn’t understood the above case, could you explain more about this?
But when I set the queue itemsize as 0, no configassert raised inside receive function?
There is no assert in the code to guard against a 0 value of item size, because an item size of 0 is used internally to implement semaphores. Also, just because there is no assert in the code for a condition, doesn’t mean that the condition is ok. The asserts are mainly there to catch the common, hard to find but easy for the code to detect, conditions.
I doesn’t understood this case, could you explain more about this or refer any link?
