1 - The Queue handle has to get from one source file/function to the source file for the ISR. Is the best way to do this through an extern declaration?
in MAIN: QueueHandle_t isrQueue;
in ISR file: extern QueueHandle_t isrQueue;
2 - The queue task for receive does not seem to be detecting the send update. Here’s the declarations:
void QueueRxFunction( void *pvParameters );
TaskHandle_t xQueueTask = NULL;
define rxQueue_RATE ( portMAX_DELAY )
The interrupt being set up and used is a timer driven interrupt to trigger an ADC read (STM32)
I have #define configLIBRARY_KERNEL_INTERRUPT_PRIORITY 15
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = configLIBRARY_KERNEL_INTERRUPT_PRIORITY
In main I call NVIC_PriorityGroupConfig( NVIC_PriorityGroup_4 ); before the scheduler launch.
The code gets to line 602 in port.c (FreeRTOS 8.2.0)
configASSERT( ucCurrentPriority >= ucMaxSysCallPriority );
And stays there. Why would it do this when the interrupt is set up for a priority of 15, which is lower than the maximum of 0 ?
In my ISR I use nothing but:
xQueueSendFromISR(isrQueue, &flag, &xHigherPriorityTaskWoken);
portEND_SWITCHING_ISR( xHigherPriorityTaskWoken );
As you suggested, I changed my code to use a regular receive queue and it’s still stopped at 602 in port.c
something I don’t understand is at the beginning of my program I print out the value of
configMAX_SYSCALL_INTERRUPT_PRIORITY and it prints out (decimal) 80
Does that mean the priority of my timer interrupt must be at least 81 for the ISR to function correctly with the queue?
Also, the value of ulCurrentInterrupt in port .c is 0, which makes no sense!
In the Timer interrupt setup, I have this:
/ #define configLIBRARY_KERNEL_INTERRUPT_PRIORITY (14)
NVIC_InitStructure.NVIC_IRQChannel = TIM6_DAC_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = configLIBRARY_KERNEL_INTERRUPT_PRIORITY;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
No matter what the #define is, the value of ulCurrentInterrupt is always 0.
I can have a proper look at this tomorrow (it’s nearly 11pm here) but first off, do you have configASSERT() defined? Assuming you are using a recent version of FreeRTOS that will catch most interrupt misconfiguration issues.
That work work fine.
In which case the interrupt priority is not valid, and you are never writing to the queue.
80 is the priority shifted up into the most significant bits of the byte. See the Cortex-M hardware documentation and RTOS for ARM Cortex-M (that link is at the top of the "my application does not run, what could be wrong) FAQ page, which is always the first place to start).
That would depend on the library you were using the set the interrupt priority. If you are using the CMSIS libraries, then no, the priority you set would have to be the unshifted value. See the link above.
I think index 0 is the stack start address - that doesn’t seem to make sense.
In any case, I think the reason your queue is not receiving is because, do to the assert() catching the invalid interrupt priority, nothing is actually being sent to it.
Hi RTE:
Now functioning! Problem - I took the suggestion on your page literally with respect to placing this “before” the scheduler launch:
After placing it in the TImer 6 configuration, and before the call to
Moving it there fixed it…the details will get you every time…
Thanks for taking the time to look at this!
