gastaronum wrote on Tuesday, January 03, 2012:
MCU: EFM32 (EnergyMicro Cortex M3)
FreeRTOS 7.0.1
I check stack allocation in function xTaskGenericCreate() and pxPortInitialiseStack(), for example:
TOP of stack = 0x200008CC, aligned TOP of stack = 0x200008C8
Aligned TOP of Stack value – 4 bytes (0x200008C4) portINITIAL_XPSR
Aligned TOP of Stack value – 8 bytes (0x200008C0) pointer to task function
Aligned TOP of Stack value – 12 bytes LR
Aligned TOP of Stack value – 16 bytes R12 (reserved for use in future)
Aligned TOP of Stack value – 20 bytes R3 (reserved for use in future)
Aligned TOP of Stack value – 24 bytes R2 (reserved for use in future)
Aligned TOP of Stack value – 28 bytes R1 (reserved for use in future)
Aligned TOP of Stack value – 32 bytes pointer to parameters, passed to the Task Function
Aligned TOP of Stack value – 36 bytes R11 (reserved for use in future)
Aligned TOP of Stack value – 40 bytes R10 (reserved for use in future)
Aligned TOP of Stack value – 44 bytes R9 (reserved for use in future)
Aligned TOP of Stack value – 48 bytes R8 (reserved for use in future)
Aligned TOP of Stack value – 52 bytes R7 (reserved for use in future)
Aligned TOP of Stack value – 56 bytes R6 (reserved for use in future)
Aligned TOP of Stack value – 60 bytes R5 (reserved for use in future)
Aligned TOP of Stack value – 64 bytes (0x20000888) R4 (reserved for use in future)
When the Task Function is called by system, firstly a values of R4 and LR is pushed to stack:
void TaskFunction(void *pvParameters)
TaskFunction:
0x14c22: 0xb510 PUSH {R4, LR}
Them pushed at address 0x200008C4 (LR) and 0x200008C0 (R4) and completely overwrite the portINITIAL_XPSR and pointer to the task function values.
Does it correct behavior?
Can I analyze the stack area (R1 … R12 values stored in the stack as reserved in pxPortInitialiseStack() function) after context switch or this area is “not for use”?
Best Regards and thanks for support.
