Question about Network buffers allocation described in "Porting FreeRTOS+TCP to a Different Microcontroller" guide
in order to include FreeRTOS+TCP in my project, I followed the guide “Porting FreeRTOS+TCP to a Different Microcontroller” as no complete examples were available for my platform.
I’m using FreeRTOS 10.2.1.
The example reported on the porting guide contains the following example for vNetworkInterfaceAllocateRAMToBuffers(…) function:
for( x = 0; x < ipconfigNUM_NETWORK_BUFFERS; x++ )
/* The following line is also required, but will not be required in future versions. */
( ( uint32_t * ) &ucBuffers[ x ][ 0 ] ) = ( uint32_t ) &( pxNetworkBuffers[ x ] );
The Network Buffer Descriptors contain a reference to the pucEthernetBuffer while this operation generate a cross-reference from the pucEthernetBuffer back to its Network Buffer Descriptor.
I verified that this is leveraged by the UDP Zero Copy flow.
It looks a temporary shortcut to get the descriptor reference from the data buffer itself. Can you clarify what “future versions” means ?
If it won’t be removed in the future, is it possible to make it more explicit ?
You understood it right: there is a mutual reference between Network buffer descriptor and the actual data buffer.
The data buffer starts 10 bytes before pucEthernetBuffer:
4-byte pointer to descriptor
6 bytes spare
14-byte Ethernet header pointed to by **pucEthernetBuffer**
20-byte IP-header
N-byte protocol (TCP/UDP)
There are 2 macro’s defining the 10-byte header:
#define ipconfigPACKET_FILLER_SIZE   ( 2 )
#define ipBUFFER_PADDING             ( 8 + ipconfigPACKET_FILLER_SIZE )
The 2 bytes (of ipconfigPACKET_FILLER_SIZE) are needed to get a correct alignment of the IP-header. The 8 bytes serve to get a good alignment for DMA.
All EMACs that I have seen until now, understand the 2-byte offset.
The routine that you point at is used by BufferAllocation_1.c only. BufferAllocation_1.2 uses pvPortMalloc() to allocate each buffer.
This comment is outdated and has disappeared from all drivers. Drivers are still responsible to set the pointer. It is not recommended to change the 2 macros here above.
Here you find the latest Network Interfaces for FreeRTOS+TCP.
If you are writing a new Network Interface, you can always ask questions here in this post.
Good examples of network interfaces are e.g. STM32Fxx and DriverSAM. Note that they use a PHY-driver (Common/phyHandling.c) that recognises most 100 Mbps Ethernet PHY’s.
