pxFillInterfaceDescriptor is undefined in RX NetworkInterface.c
Greetings,
I developed an application which runs on the Renesas RX65N MCU.
Now, I am updating the application from FreeRTOS 202210.00 LTS to 202406.01 LTS, which means FreeRTOS-Plus-TCP will also be updated from v3.1.0 to v4.2.2.
After applying FreeRTOS-Plus-TCP v4.2.2, I encountered build error due to pxFillInterfaceDecscriptor function being undefined.
Scanning through the commit history and pull requests(PR#755) of FreeRTOS-Plus-TCP, I noticed that the function was fully implemented for certain vendors only.
Request
  1. Please kindly advise how to proceed about this minor improvement? I would like to enable backward compatibility for FreeRTOS-Plus-TCP.
  2. May I know why the backward compatibility code was fully implemented for selected vendors only?
Thank you.
@naux5566
With FreeRTOS+TCP version v4 and above, the FreeRTOS+TCP added support for IPv6 and multiple interfaces & endpoints. Hence the function name pxFillInterfaceDescriptor has been changed to name unique to the interface.
If you would like to use the network interface port with backward compatibility enabled then its required to add the following lines in your network interface file:
#if ( ipconfigIPv4_BACKWARD_COMPATIBLE != 0 )
/* Do not call the following function directly. It is there for downward compatibility.
 * The function FreeRTOS_IPInit() will call it to initialice the interface and end-point
 * objects.  See the description in FreeRTOS_Routing.h. */
    NetworkInterface_t * pxFillInterfaceDescriptor( BaseType_t xEMACIndex,
                                                    NetworkInterface_t * pxInterface )
        return pxRX_FillInterfaceDescriptor( xEMACIndex, pxInterface );
If you are planning to use it without backward compatibility (recommended for latest features), then the application should call the interface specific fill interface descriptor before the FreeRTOS+TCP is initialized (you should also change your FreeRTOS+TCP initialization code similar to the example in the link):
	extern NetworkInterface_t * pxRX_FillInterfaceDescriptor( BaseType_t xEMACIndex,
                                                        NetworkInterface_t * pxInterface );
	/* Initialize the interface descriptor for RX. */
	pxRX_FillInterfaceDescriptor(0, &(xInterfaces[0]));
  1. May I know why the backward compatibility code was fully implemented for selected vendors only?
Since vendor specific network interface files aren’t core part of the FreeRTOS+TCP and is more of a reference, not all sample network interfaces have been tested with backward compatibility enabled.
Please feel free to raise a pull request to the FreeRTOS+TCP repo if you would like to make the changes necessary for backward compatibility in the network interface you are using.
Thanks for the reply @tony-josi-aws .
I will raise a pull request for the code change above.
A pull request has been submitted for this issue.
Updated RX portable layer for backward compatibility · Pull Request #1182 · FreeRTOS/FreeRTOS-Plus-TCP (github.com)
Thank you.
The PR is stalled and needs a patch. Can you take a look and apply the patch provided by aggarg?
