I have some doubts, please forgive trivial question.
from documentation about taskENTER_CRITICAL()
"Macro to mark the start of a critical code region. Preemptive context switches cannot occur when in a critical region."
We disable interrupts but other type of context switch can still happened(?)
lets consider that code, aim is protect variable "protectedVar":
Its not actually a trivial question.
> from documentation about taskENTER_CRITICAL() "Macro to mark
The key here is ‘Preemptive’. The critical region protects against preemptive context switches - what happens for other types of context switch actually depends on the port but for nearly all ports users can force a context switch within a critical section if they want. It would not be normal to do so, but you have the flexibility if you want it. One case where you may want this ability is to ensure that when a task starts executing again (gets switched back in) that it immediately has exclusive access to some resource.
Thank You Richard.
That’s clear. May be useful if this hint will be in documentation, what you think?
So in theory, if I do not need that feature I can remove maintaining uxCriticalNesting for every task and keep global variable? or there could be some side effects depend on port?
No - the kernel code itself uses the feature, although I am moving away from this reliance in the newer ports. The critical nesting count has to remain as part of the task context.
