I am using an STM32F207 platform and the ST HAL drivers. One of the I2C interfaces is connected to a Microchip MCP23017 GPIO expander. The GPIO expander has its interrupt output pin connected to a GPIO pin on the STM32F207.
When the interrupt is triggered the HAL calls HAL_GPIO_EXTI_IRQHandler() which clears the interrupt within the microcontoller and then calls HAL_GPIO_EXTI_Callback().
Should HAL_GPIO_EXTI_Callback() do the actual work of reading the GPIO expander to determine what caused the interrupt and then pass that information to a FreeRTOS task to deal with it or should HAL_GPIO_EXTI_Callback() simply wake up a FreeRTOS task and have the task read the GPIO expander?
The first time the hardware interrupt fires I am getting an assert thrown in FreeRTOS/portable/GCC/ARM_CM3/port.c at line 686.
/* The following assertion will fail if a service routine (ISR) for
* an interrupt that has been assigned a priority above
* configMAX_SYSCALL_INTERRUPT_PRIORITY calls an ISR safe FreeRTOS API
* function. ISR safe FreeRTOS API functions must *only* be called
* from interrupts that have been assigned a priority at or below
* configMAX_SYSCALL_INTERRUPT_PRIORITY.
* The following links provide detailed information:
* https://www.FreeRTOS.org/RTOS-Cortex-M3-M4.html
* https://www.FreeRTOS.org/FAQHelp.html */
configASSERT( ucCurrentPriority >= ucMaxSysCallPriority );
I’ve checked the referenced page that talks about Cortex-M3 and M4 and have confirmed that the HAL_Init() function is calling NVIC_PriorityGroupConfig() as per the big red warning!
I’m guessing this is probably down to the priority the handling task is being created with (uxPriority is set to 2 when the handling task is created with xTaskCreate().
