Grep’ing the source code for “28” I see it defined as “F_ERR_ALLOCATION”.
Other than that, place a break point on your call to f_getcwd(), then
step through the code from there, until you find the code that is
generating the error.
After inserting the break point printf(“string\n”) into the f_getcwd()(the same as fn_get_cwd()) , the output terminal does not enter this f_getcwd() and shows any breakpoint informations. I guess one thing is that This read / write code too big, so the mcu system can not afford this . Another guess is that I changed one type of variables. The yellow marked parts is that I changed from “BaseType_t” to “int”.
I do not know why should defined this BaseType_t, because I think it is only a number. When Compiling, it shows you havn’t defined. So for me, I used Xtensla 32 bit CPU for my board. Should I defined the
BaseType_t as shown below ?
Note: The modified souce code of Sample Read Write Demo Code from FreeRTOS.org as shown in the attached files.! #define BaseType_t 32;
BaseType_t is defined in every port layer, so probably 30 or more different definitions in the FreeRTOS source, did you look at any of those? I guess not because you would see its not a number.
It must be defined anyway, otherwise FreeRTOS would not compile.
Ya, After Finding the freertos portmacro.h, there are severval port definitions, and I also include , and compile with no problem, However, the same problem always encouter . fatal exception(28) is always shown on my com terminals. SPIFF File System Read /Write that ESP9266 WiFi SOC Chip provided is used as an example for us to be shown. I do not know what exactly FreeRTOS use which kind of File System Operation to do. But I guess, due to the limitation of Memory Size, The ESP8266 can not afford this kind of data read /write operation that FreeRTOS provided.So, Maybe oneday you can provdi Xtensia CPU in ESP8266 suitable Codes for Use
