Hello all
I have a product with the Atmel ARM7 AT9SAM7S256 running using freeRTOS 5.1.2 originally using IAR EWARM 4.42, and I am trying to move it to v5.30. The product sort of runs (!) but behaves erratically and some sprintf typ eoperations don’t work as expected, particularly printing the (dramatically) wrong values.
I have started a discussion with IAR, who say the the biggest cause of this sort of problem is stack missalignment. v5 comilers need/expect 8byte allignment on the stack when entering/leaving C functions.
It seems that the freeRTOS5 attempts to match this , but I have a problem in my understanding. When creating a new task, tasks.c gets an aligned stack which I have ensured is a multiple of 8bytes in size by making sure usStackDepth is even. Then the top of stack pointer is guaranteed to be 4 byte aligned as
pxTopOfStack = pxNewTCB->pxStack + ( usStackDepth - 1 );
Then pxPortInitialiseStack adds 17 4byte registers to the stack. It seems to me that this ought to be 18 registers, and the portRESTORE_CONTEXT and portSAVE_CONTEXT macros need adjusting similarly, or am I misunderstanding it all?
Any helpful hints comments and thoughts gratefully received.
Hi again Dave
I have been looking further into my (possible) stack alignment problem, and have com across the following:
In xTaskCreate, if usStackDepth is even, pxTopOfStack will always be an odd value, representing a none-8byte aligned stack, and thus giving me my problems with some functions. If I force usStackDepth to be odd, this effectively forces pxTopOfStack to be even, so the stack starts (and will remain) 8byte aligned.
Does this make sense?
By observation, this seems to give a reliable build, with all the combinations of optimisatoins and such that I have tried, but I would like:
a)
Hi again Dave
a) is this a sensible explanation of the problems I have been seeing.
b) an elegant way of fixing the underlying cause. I have just bodged in a ‘usStackDepth |= 1;’ at the start of xTaskCreate, but I guess it needs to be used if portSTACK_GROWTH is negative, portBYTE_ALIGNMENT is bigger than sizeof( portSTACK_TYPE ), but I am not aware of all the possible ramifications!
