cc1: error: unrecognized command line option ‘-mthumb’
cc1: warning: ‘-mcpu=’ is deprecated; use ‘-mtune=’ or ‘-march=’ instead
main.c:1:0: error: bad value (cortex-m3) for -mtune= switch
Which options should I use? Or can I remove these safely?
The " …/…/…/Source/include" option should point to the correct directory. I even tried adding a -I option with an absolute path to this, it didn’t change anything.
Would you have any idea what’s causing this error?
The Eclipse page you reference is very very old. Eclipse has moved on a long way from then, but I think it just uses a makefile build not a managed make build.
I’m pretty sure you need to be using arm-stellaris-eabi compiler, not arm-non-eabi compiler. arm-non-eabi will work but is newer and will need the compiler options adjusting, as you have found out.
I had tried pointing to the include directory both in the project and in this makefile (although the bath should be correct as it is there), without success.
For the compiler, I am getting it from the “CodeBench/Sourcery Lite for ARM EABI”. I think the arm-stellaris-eabi is the one included in the paid version?
They used to have both available as free lite version downloads, but I don’t know how things have changed since they were acquired by Mentor.
You should be able to use the arm-non-eabi-gcc compiler too, but will have to change the compiler configuration options. There are other makefiles that show the options needed that you can copy.
