Problem with Static Task Creation - TrueStudio, freeRTOS, "Invalid selected thread"
alho wrote on Monday, September 17, 2018:
I’m troubleshooting a problem with task creation in freeRTOS, Atollic TrueStudio, STM32.
In the first call of xTaskCreateStatic() the code runs into an error: “Invalid selected thread”. When debugging I can see that the pxNewTCB gets initialized correctly in prvInitialiseNewTask( ). But in prvAddNewTaskToReadyList( ) the code breaks at the assignment of pxNewTCB to pxCurrentTCB:
static void prvAddNewTaskToReadyList( TCB_t *pxNewTCB )
	/* Ensure interrupts don't access the task lists while the lists are being
	updated. */
	taskENTER_CRITICAL();
		uxCurrentNumberOfTasks++;
		if( pxCurrentTCB == NULL )
			/* There are no other tasks, or all the other tasks are in
			the suspended state - make this the current task. */
			pxCurrentTCB = pxNewTCB;
I couldn’t find something related to this problem in the freeRTOS or STM/Atollic forum but something that looks similar in the openstm32 forum http://www.openstm32.org/forumthread2824 …but it didn’t help me.
I double checked the task settings, priority, stack size,… but I don’t find something that looks wrong.
If I deactivate the first taks creation (call of the xTaskCreateStatic() ) it gets stuck at the second (or now first) call of xTaskCreateStatic().
Any ideas what might cause the problem and how to solve it?
If I shall post more stuff, please let me know!
I’m using TrueStudio V9, freeRTOS V9, basic code generated with CubeMX(V4.25.1), Debugger j-link Ultra+.
Regards,
Alex
alho wrote on Tuesday, September 18, 2018:
an addition; I was experimenting with the Debug Config.
When I deactivate Thread-aware RTOS support (No RTOS), debugging the code seems to work. I can still debug RTOS for SEGGER SysView. The code runs good, didn’t find something unexpected yet. Anyway I can’t tell why this could be a problem, because I got the “extra” expression…
thread 2
continue
…in my Startup Script. But if this is the best solution, I will do it like that.
Next experiment:
When I deactivate Thread-aware RTOS support AND Trace System (I use SWV), the code runs into assertion. It then seems to mess up with SystemView, because when I deactivate SystemView (not calling SEGGERSYSVIEWConf() ), the code is running without problems.
Well, at least I found a workaround to be able to keep on working. But still I have the feeling that there must be something horrible wrong in the project…maybe somebody has an idea with this new information?
Regards,
Alex
rtel wrote on Tuesday, September 18, 2018:
For some reason my reply to your first post, some ten hours ago, never showed up here. It was:
I’m afraid your description isn’t really clear enough for me to determine what the issue you are reporting is.
In the first call of /xTaskCreateStatic()/ the code runs into an error: “Invalid selected thread”.
Where is this error, by which I mean how did you determine that was the error?
When debugging I can see that the /pxNewTCB/ gets initialized correctly in /prvInitialiseNewTask( )/. But in /prvAddNewTaskToReadyList( )/ the code breaks at the assignment of /pxNewTCB/ to /pxCurrentTCB/:
What is meant by the code ‘breaking’? Does it crash, and if so, how does that crash occur? Is it related to the “Invalid selected thread” error from above?
If I deactivate the first taks creation (call of the /xTaskCreateStatic()/ ) it gets stuck at the second (or now first) call of /xTaskCreateStatic()/
Do you have configASSERT() defined so it checks the size of the static task structure against the non static task structure? If you have something like configUSE_LIST_DATA_INTEGRITY_CHECK_BYTES defined then the structures could be different sizes, which would cause a problem.
alho wrote on Wednesday, September 19, 2018:
Hi Richard,
thanks for the reply. I’ll try to answer your questions.
The problem, however, is that the error is gone. I can’t reproduce it right now. I jumped back in my code history when it occured but I can’t trigger it now…must be evil black magic.
The error was outputted on the debugging console. The code crashed and I was able to isolate it to the assignment mentioned above (pxCurrentTCB = pxNewTCB). The scheduler didn’t start at that point yet, it was all during initialization.
At the moment it’s hard to tell you more as I cannot reproduce it. configASSERT() is defined, configUSE_LIST_DATA_INTEGRITY_CHECK_BYTES is not defined (gets defined to 0 in projdef.h by default).
I will try to reproduce the error and make more and detailed tests if it occurs.
