Hi, I have been trying to build a project off of the greengrass discovery demo on a esp32 wrover devkit v3. In my project I plan to use a ring buffer and some peripherals including GPIOs, UART, and SPI. The demo works fine right out of the box, but when I started adding my own setup code for either UART, SPI, or creating a ring buffer, the demo fails. I have tried increasing the stack size of the greengrass demo to something much larger like 80,000 bytes and that still didn’t help. Does anyone know what kind of complication initializing a ringbuffer or UART, SPI, and their respective configuration structs could create? Whats also interesting is even if my code to setup a ringbuffer is AFTER the greengrass discovery demo function it still causes the greengrass discovery to fail. Here are the logs when the failure happens and also the code I added to the function vStartGreenGrassDiscoveryTask():
I (2678) WIFI: SYSTEM_EVENT_STA_CONNECTED
3 828 [IP-task] vDHCPProcess: offer a000058ip
I (8728) event: sta ip: 10.0.0.88, mask: 255.255.255.0, gw: 10.0.0.1
I (8728) WIFI: SYSTEM_EVENT_STA_GOT_IP
4 838 [IP-task] vDHCPProcess: offer a000058ip
5 839 [iot_thread] [INFO ][DEMO][8390] Successfully initialized the demo. Network type for the demo: 1
6 839 [iot_thread] Attempting automated selection of Greengrass device
7 1038 [iot_thread] ERROR: Handshake failed with error code -16
8 1038 [iot_thread] About to close socket.
9 1039 [iot_thread] Socket closed.
10 1039 [iot_thread] Stack high watermark for discovery helper task: 5488.
11 1039 [iot_thread] JSON request could not connect to end point
12 1039 [iot_thread] Auto-connect: Failed to retrieve Greengrass address and certificate.
13 1039 [iot_thread] ----Demo finished----
RingbufHandle_t ring_buffer;
int vStartGreenGrassDiscoveryTask(bool awsIotMqttMode,
const char *pIdentifier,
void *pNetworkServerInfo,
void *pNetworkCredentialInfo,
const IotNetworkInterface_t *pNetworkInterface)
/* Unused parameters */
(void)awsIotMqttMode;
(void)pIdentifier;
(void)pNetworkServerInfo;
(void)pNetworkCredentialInfo;
(void)pNetworkInterface;
prvDiscoverGreenGrassCore(NULL);
ring_buffer = xRingbufferCreate(RING_BUFFER_SIZE, RINGBUF_TYPE_ALLOWSPLIT);
configASSERT(ring_buffer);
return 0;
Thank you very much for the insight! I had some large statically allocated global variables that I had brought in from other code. Once I made them a lot smaller my code to initialize peripherals and ring buffer worked.
Although in the code you posted, I believe that the vPortFree() needs to be after the call to prvSendMessageToGGC() because I think xHostAddressData is using memory that gets freed otherwise.I was getting errors like this:
13 1448 [iot_thread] [ERROR][NET][14480] Failed to resolve ��EXX٦�?Į�?.
14 1448 [iot_thread] [ERROR][MQTT][14480] Failed to establish new MQTT connection, error NETWORK ERROR. 15 1448 [iot_thread] ERROR: Could not connect to the Broker.
16 1448 [iot_thread] failed to connect to MQTT Agent
17 1448 [iot_thread] Heap low watermark: 9140. Stack high watermark: 5084.
I have a follow up question, do you need to use the demo routine to use greengrass discovery functions? For example, now the project works if I add my setup code in the vStartGreengrassDiscoveryTask() function but I am trying to just use an initialization function for all my setup and tasks from app_main() and then connect to the greengrass core. In the initialization function, I first initialize the wifi in station mode with my network credentials and then start greengrass discovery but eventually prvMQTTConnect() fails with the logs below. I already traced the NETWORK_ERROR back to pdFREERTOS_ERRNO_ETIMEDOUT in FreeRTOS_Connect().
5 1392 [main] About to close socket.
6 1397 [main] Socket closed.
7 1397 [main] Stack high watermark for discovery helper task: 5324.
8 1397 [main] Greengrass device discovered.
9 1397 [main] Establishing MQTT communication to Greengrass...
10 1398 [main] Connecting to Host Adrress: 10.0.0.50, Port: 8883
I (14319) prvSendMessageToGGC: Free Heap Size: 92284
11 1899 [main] [ERROR][NET][18990] Failed to establish new connection.
12 1899 [main] [ERROR][MQTT][18990] Failed to establish new MQTT connection, error NETWORK ERROR.
13 1899 [main] ERROR: Could not connect to the Broker.
14 1899 [main] failed to connect to MQTT Agent
15 1900 [main] Heap low watermark: 30284. Stack high watermark: 5324.
16 1901 [main] ----Demo finished----
So I’m wondering if there is anything in the _initialize() function in iot_demo_freertos.c or the rest of the AWS demo framework that I need to do for the greengrass discovery to succeed. I even changed the task stack size for the main_task to democonfigGREENGRASS_DISCOVERY_TASK_STACK_SIZE but that didn’t help.
Could you please turn on the FreeRTOS+TCP stack logging in vendors\espressif\boards\esp32\aws_demos\config_files\FreeRTOSIPConfig.h by setting ipconfigHAS_DEBUG_PRINTF to 1.:
#define ipconfigHAS_DEBUG_PRINTF 1
Then run again to see any issues in the the TCP/IP stack that may cause a timeout.
So it looks like the combination of two things fixed this issue, all I had was this a wifi initialization function before that connected to the AP in station mode with my credentials. But then I added IoTSdk_Init() before that. At that point I noticed that if I debug and pause the ESP32 when it is stuck in prvMQTTConnect() that it was stuck in function vApplicationStackOverflowHook. So then I increased the task stack size of the app_main() to the same stack size as democonfigGREENGRASS_DISCOVERY_TASK_STACK_SIZE and then the ggd demo was able to complete.
