I am getting compilation error, when i try to compile FreeRtos with Rowley’s Crossworks for STM32F207IG.
I am using version 6.1.0 of freeRtos. I am getting a compilation error in the File “queue.c” & port.c
The error are “undefined reference to vPortSetInterruptMask”
Building “Example” in configuration “THUMB Debug”
Compiling queue.c
Linking Example.elf
THUMB Debug/queue.o: In function `xQueueGenericSendFromISR’:
undefined reference to `vPortSetInterruptMask’
undefined reference to `vPortClearInterruptMask’
THUMB Debug/tasks.o: In function `vTaskStartScheduler’:
THUMB Debug/port.o: In function `vPortEnterCritical’:
THUMB Debug/port.o: In function `vPortExitCritical’:
THUMB Debug/port.o: In function `xPortSysTickHandler’:
Build failed
Where did the project come from? I’m using FreeRTOS V7.3.0 and there isn’t a vPortSetInterruptMask() function or macro in the CM3 GCC port layer.
I just tried compiling the FreeRTOS\Demo\CORTEX_STM32F107_GCC_Rowley demo and didn’t get any problems (there were 17 warnings that came from the uIP stack code, but it compiled and linked).
Thanks for the reply, I am using freeRtos V6.1. I have used the source file from other FreeRTOS project Build on Different IDE.
The Project is based on demonstration of building on top of the LwIP (Lightweight IP) TCP/IP stack.
I have also tried & compilied FreeRTOS\Demo\CORTEX_STM32F107_GCC_Rowley demo without any errors, but i cannot use this, as I am using STM32F207IG based Development board.
All the Cortex-M3 demos use exactly the same port layer code. FreeRTOS does not care if it is a 107 or a 207, but you will have to change the linker script to have the correct memory layout.
