ozsmit wrote on Wednesday, November 21, 2012:
I agree, It seems to work fine.
How would I fix the checkTask Fail problem? It seems like a nice feature to have.
My project has the following tasks:
/* Create the queue used to pass message to vPrintTask. */
xPrintQueue = xQueueCreate( mainQUEUE_SIZE, sizeof( char * ) );
/* Create the semaphore used to wake vButtonHandlerTask(). */
vSemaphoreCreateBinary( xButtonSemaphore );
xSemaphoreTake( xButtonSemaphore, 0 );
/* Start the standard demo tasks. */
vStartIntegerMathTasks( tskIDLE_PRIORITY );
vStartPolledQueueTasks( mainQUEUE_POLL_PRIORITY );
vStartSemaphoreTasks( mainSEM_TEST_PRIORITY );
vStartDynamicPriorityTasks();
vStartBlockingQueueTasks( mainBLOCK_Q_PRIORITY );
#if configUSE_PREEMPTION == 1
/* The timing of console output when not using the preemptive
scheduler causes the block time tests to detect a timing problem. */
vCreateBlockTimeTasks();
vStartRecursiveMutexTasks();
/* Start the tasks defined within this file. */
xTaskCreate( vLEDTask, ( signed char * ) “LED”, configMINIMAL_STACK_SIZE, NULL, mainLED_TASK_PRIORITY, NULL );
xTaskCreate( vCheckTask, ( signed char * ) “Check”, configMINIMAL_STACK_SIZE, NULL, mainCHECK_TASK_PRIORITY, NULL );
xTaskCreate( vPrintTask, ( signed char * ) “Print”, configMINIMAL_STACK_SIZE, NULL, mainPRINT_TASK_PRIORITY, NULL );
xTaskCreate( vButtonHandlerTask, ( signed char * ) “Button”, configMINIMAL_STACK_SIZE, NULL, mainCHECK_TASK_PRIORITY, NULL );
/* Start the scheduler. */
vTaskStartScheduler();
And I am using the follwoing checkTask():
static void vCheckTask( void *pvParameters )
portBASE_TYPE xErrorOccurred = pdFALSE;
portTickType xLastExecutionTime;
const char * const pcPassMessage = “PASS\n”;
const char * const pcFailMessage = “FAIL\n”;
/* Just to remove compiler warnings. */
( void ) pvParameters;
/* Initialise xLastExecutionTime so the first call to vTaskDelayUntil()
works correctly. */
xLastExecutionTime = xTaskGetTickCount();
for( ;; )
/* Perform this check every mainCHECK_DELAY milliseconds. */
vTaskDelayUntil( &xLastExecutionTime, mainCHECK_DELAY );
/* Has an error been found in any task? */
if( xAreIntegerMathsTaskStillRunning() != pdTRUE )
xErrorOccurred = pdTRUE;
if( xArePollingQueuesStillRunning() != pdTRUE )
if( xAreSemaphoreTasksStillRunning() != pdTRUE )
if( xAreDynamicPriorityTasksStillRunning() != pdTRUE )
if( xAreBlockingQueuesStillRunning() != pdTRUE )
if( xAreBlockTimeTestTasksStillRunning() != pdTRUE )
if( xAreRecursiveMutexTasksStillRunning() != pdTRUE )
/* Send either a pass or fail message. If an error is found it is
never cleared again. */
if( xErrorOccurred == pdTRUE )
xLED_Delay = mainERROR_LED_DELAY;
xQueueSend( xPrintQueue, &pcFailMessage, portMAX_DELAY );
xQueueSend( xPrintQueue, &pcPassMessage, portMAX_DELAY );
I should probably set a break point to see which one fails, however I am away from my developement platform at the moment.
Ozmit
