Good morning,
I have developed the following code to test how freeRTOS implements priority inheritance through mutex.
But when I run I notice that task 2 is executed before task 3 which should be executed by priority inheritance.
Task3-1 accedo s12
before take S12
after take S12
Task1-1 duermo
Task1-2 accedo s11
before take S11 -> Here the next task should be 3
Task2-1 duermo
Task2-2 acced0 s21
before take S21
after take S21
Before give S21
after give S21
Task2-3 espero periodo
Before give S12
Code:
#if CONFIG_FREERTOS_UNICORE
#define ARDUINO_RUNNING_CORE 0
#else
#define ARDUINO_RUNNING_CORE 1
#if CONFIG_FREERTOS_TIMER_TASK_PRIORITY
#define CONFIG_FREERTOS_TIMER_TASK_PRIORITY 24
#define configUSE_MUTEXES 1
#define configTIMER_TASK_PRIORITY (configMAX_PRIORITIES - 1) // la maxima prioridad
void CS (int ms);
definicion de task
TaskHandle_t task1;
TaskHandle_t task2;
TaskHandle_t task3;
void vTask1(void *pvParameters);
void vTask2(void *pvParameters);
void vTask3( void *pvParameters );
Definicion de semaforos
SemaphoreHandle_t semaforoS1;
SemaphoreHandle_t semaforoS2;
definicion de servidores
// the setup function runs once when you press reset or power the board
void setup() {
// initialize serial communication at 115200 bits per second:
Serial.begin(115200);
Serial.println(configUSE_MUTEXES);
TickType_t xLastWakeTime;
xLastWakeTime = xTaskGetTickCount(); //extraemos el tiempo
/***********************************************************************Semaforos***********************************************************************/
semaforoS1 = xSemaphoreCreateMutex();
semaforoS2 = xSemaphoreCreateMutex();
/***********************************************************************Tareas*************************************************************************************/
// Create the task to access the shared resource.
xTaskCreatePinnedToCore(
vTask1
, "Task1"
, 1024 // Stack size
, (void*) xLastWakeTime
, 5 // Priority
, &task1
, ARDUINO_RUNNING_CORE);
vTask2
, "Task1"
, 3 // Priority
, &task2
vTask3
, "Task1"
, 1 // Priority
, &task3
/********************************************************************* fin tareas *************************************************************************************/
void loop()
void vTask1( void *pvParameters )
const TickType_t xDelay100ms = pdMS_TO_TICKS(100);
const TickType_t xTicksToDelay = pdMS_TO_TICKS(10);
vTaskDelay(pdMS_TO_TICKS(10)); //Realizamos una espera 10ms inicial
xLastWakeTime = (TickType_t) pvParameters; //extraemos el tiempo
for (;;) {
//para durante 1000
Serial.println("Task1-1 duermo");
CS(10);
Serial.println("Task1-2 accedo s11");
S11 () ; //accedemos al servidor 1
Serial.println("Task1-3 espero periodo");
vTaskDelayUntil( &xLastWakeTime, xDelay100ms ); //esperamos 100ms
void vTask2( void *pvParameters )
const TickType_t xDelay200ms = pdMS_TO_TICKS(200);
const TickType_t xDelay60ms = pdMS_TO_TICKS(60);
for (;;) {
Serial.println("Task2-1 duermo");
CS(60);
Serial.println("Task2-2 acced0 s21");
S21 () ; //accedemos al servidor 1
Serial.println("Task2-3 espero periodo");
vTaskDelayUntil( &xLastWakeTime, xDelay200ms ); //esperamos 100ms
const TickType_t xDelay400ms = pdMS_TO_TICKS(400);
const TickType_t xDelay30ms = pdMS_TO_TICKS(30);
vTaskDelay(pdMS_TO_TICKS(5)); //espera inicial de 5
for (;;) {
Serial.println("Task3-1 accedo s12");
S12 () ;
Serial.println("Task3-2 duermo");
CS(30);
Serial.println("Task3-3 accedo s22");
S22 () ;
Serial.println("Task3-4 espero periodo");
vTaskDelayUntil( &xLastWakeTime, xDelay400ms ); //esperamos 100ms
/*********************************** Servidores *********************************************************************************************************************/
// Servidor S1
void S11 (void) {
Serial.println("before take S11");
xSemaphoreTake( semaforoS1, portMAX_DELAY );
Serial.println("after take S11");
CS(10);
Serial.println("Before give S11");
xSemaphoreGive( semaforoS1 );
Serial.println("after give S11");
void S12 (void) {
Serial.println("before take S12");
Serial.println("after take S12");
CS(20);
Serial.println("Before give S12");
Serial.println("after give S12");
// Servidor S2
void S21 (void) {
Serial.println("before take S21");
xSemaphoreTake( semaforoS2, portMAX_DELAY );
Serial.println("after take S21");
CS(30);
Serial.println("Before give S21");
xSemaphoreGive( semaforoS2 );
Serial.println("after give S21");
void S22 (void) {
Serial.println("before take S22");
Serial.println("after take S22");
CS(20);
Serial.println("Before give S22");
Serial.println("after give S22");
void CS (int ms) {
int i, j ;
for (j = 0; j < ms; j++){
for (i = 0; i < 1410; i++) ;
Can you help me understand why this is happening and how to solve it? thanks in advance.
