I used FreeRTOS on cortex M4 with tickless mode. For timing RTOS I was used to using RTC insted of Systick (because of depth of sleep mode). In M4 I set priority for RTC timer using configLIBRARY_LOWEST_INTERRUPT_PRIORITY (HAL_NVIC_SetPriority(RTC_IRQn, configLIBRARY_LOWEST_INTERRUPT_PRIORITY, 0);)
OK, but now I want to use the same on cortex M0+, but there is no macro like configLIBRARY_LOWEST_INTERRUPT_PRIORITY or configLIBRARY_MAX_INTERRUPT_PRIORITY. How should I set the priority for system timer and other periphery?
On the Cortex-M0+ there is no masking of different priority levels. Either all exceptions with configurable priority are enabled or disabled. Although the interrupts can nest, if PRIMASK is set to 1 (masked) then they will not nest or pre-empt each other so it is not important.
Yes. I think that will be be fine. The reason for the way it is done on the Cortex-M4 is to stop any interrupts which access the API from corrupting API operations in other interrupts. This is not a problem in this port unless you enable interrupts whilst in an interrupt.
