How can i write hex commands? ESP8266 will communicate (on-off a relay) with other mcu by this serial command:
“0xA0 0x01 0x01 0xA2”
(lctech device : http://www.chinalctech.com/cpzx/1/333.html)
Working Arduino example:
byte relON[] = {0xA0, 0x01, 0x01, 0xA2}; //Hex command to send to serial for open relay
byte relOFF[] = {0xA0, 0x01, 0x00, 0xA1}; //Hex command to send to serial for close relay
int ledState = false;
unsigned long previousMillis = 0;
const long interval = 2000; // 2 seconds
// the setup function runs once when you press reset or power the board
void setup() {
// initialize serial:
Serial.begin(9600);
// the loop function runs over and over again forever
void loop()
unsigned long currentMillis = millis();
if(currentMillis - previousMillis >= interval) {
previousMillis = currentMillis;
if (ledState == true) {
Serial.write(relON, sizeof(relON)); // turns the relay ON
ledState = false;
} else {
Serial.write(relOFF, sizeof(relOFF)); // turns the relay OFF
ledState = true;
it doesnt work…
