kkoovalsky wrote on Tuesday, December 11, 2018:
Hello all.
I’m running FreeRTOS V9.0.0 on STM32L432KC.
I have a problem in preventing the device from going to sleep. At startup I have some tasks which I need to run without sleep. They use vTaskDelay and also some of the tasks use functions like xQueueReceive with timeouts which are finite (no portMAX_DELAY). The problem is that when one of the tasks gets blocked on such functions the device goes to sleep and I do not want it to. In general I want to implement some kind of mechanism which allows to prevent from sleeping if there are tasks which wait for something with a finite timeout. I can’t find any API which allows me to distinguish tasks which wait for something with finite timeout (e.g. those which have called vTaskDelay(pdMS_TO_TICKS(200)), xQueueReceive(q, pdMS_TO_TICKS(200)), xSemaphoreTake(mux, pdMS_TO_TICKS(200))… ) from those which are blocked indefinitely (xQueueReceive(q, portMAX_DELAY), xSemaphoreTake(mux, portMAX_DELAY)… ) .
The second problem is that I want to determine that in the configPRE_SLEEP_PROCESSING() callback (it’s a macro - I know - but in general it’s defined as a callback in my app). When I try to call uxTaskGetSystemState in the callback I get a hardfault. I don’t know then whether I can call FreeRTOS specific functions in this callback and I can’t find any information about that in the documentation.
I’m thinking about two solutions:
- Implement some kind of internal FreeRTOS mechanism, but then I need to edit FreeRTOS code, what’s quite intrusive and I don’t want to do it
- Instead of using
vTaskDelayimplement a mechanism based on a hardware timer which wakes up the task after the specifed time and the timer is able to wake up the device from sleep. The problem here is that I would need to connect somehow the timer with the FreeRTOS code for the task which call functions likexQueueReceiveorxSemaphoreTakewith a finite timeout. - Manually add some flags which can be set/reset from task code and checked in the
configPRE_SLEEP_PROCESSINGcallback. This is for me an ugly solution (but the simplest one) because every programmer in the team needs to remember about that when implementing a task, it can be error-prone and time-wasting when debugging.
My question is if there is some kind of out of the box mechanism in FreeRTOS which allows to implement 2. solution or is there a way to determine in theconfigPRE_SLEEP_PROCESSINGcallback whether any task is in the “delayed” state, what means that it is waiting for something with a finite timeout?
