Posix_GCC demo: stack smashing detected
Hello everyone,
I am new in FreeRTOS and I am trying to execute de Posix_GCC on Ubuntu 22.04.4 LTS.
I am using gcc 11.4.0 and make 4.3
When I launch the ./posix_demo I got this
[WARN] pthread_attr_setstack failed with return value: 22. Default stack will be used.
[WARN] Increase the stack size to PTHREAD_STACK_MIN.
Trace started.
The trace will be dumped to disk if a call to configASSERT() fails.
Starting full demo
*** stack smashing detected ***: terminated
Any suggestion is really appreciated.
Thank you in advance.
Which version are you using? I tried the mainline and I do not see this crash. Here is my command history:
gh repo clone git@github.com:FreeRTOS/FreeRTOS.git
cd FreeRTOS/
git submodule update --init --recursive
cd FreeRTOS/Demo/Posix_GCC/
make
./build/posix_demo
And here is the output I see -
Trace started.
Starting full demo
OK: No errors - tick count 10001
OK: No errors - tick count 20001
make and gcc versions are also same as yours:
$ make --version
GNU Make 4.3
Built for x86_64-pc-linux-gnu
Copyright (C) 1988-2020 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
$ gcc --version
gcc (Ubuntu 11.4.0-1ubuntu1~22.04) 11.4.0
Copyright (C) 2021 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
I downloaded the code from the web site, not from GIT.
I have been requested for other project for some days.
When I get round to test it, I will let you know the result
Thank you for your answer
Jose
It works.
What is on the website and what is on GitHub is not the same.
THANK YOU SO MUCH !!!
Thank you for reporting back!
