I recently worked on a project integrating MPU on Cortex-M4.
I notice that in freeRTOS 10.5.1 with mpu wrapper v1, I could use portSVC_RAISE_PRIVILEGE() to enter privileged mode inside application code.
However, the same code didn’t work when upgrading to freeRTOS 11.1.0 with mpu wrapper v2. I confirmed that I have configured in the FreeRTOSConfig.h to use mpu wrapper v2.
And then I checked the code and seems portSVC_RAISE_PRIVILEGE is only supported when using mpu wrapper v1.
My question is for v2, how to let application functions access system core registers like SCB and NVIC without using portSVC_RAISE_PRIVILEGE ?
I have tried using portPRIVILEGE_BIT and made my application tasks run in privileged mode and it worked. I am wondering if there is any other solutions.
Hi @pasu
In the current FreeRTOS Kernel (v10.6.2 + ) , MPU wrappers were updated to address security concerns. As a result, an unprivileged task may access a valid kernel object using legitimate system calls which it is not supposed to access.
You cannot directly call portSVC_RAISE_PRIVILEGE for raising privilege of an unprivileged task with mpu wrapper v2.
The process you are following correct, is making the application task a privileged task for it to be able to access Kernel objects.
You can read more about the access control of various tasks in the threat model here
You should ensure that the privileged task only does things that are needed to be done in privileged mode to minimize the threat surface. Refer to the threat model that @karahulx shared.
By the way, with the existing system calls in mpu wrapper v2, is there any system calls that could help me read registers like Systick or NVIC ?
If it’s not possible, then seems the only thing I could do is to create a new privileged task to read register values for other application tasks. Am I correct ? feels a bit inefficient if other applications tasks need to wait for privileged task to read register for them…
Are mpu wrapper v1 and v2 meant to be co-exist in the future ? or eventually v1 would be deprecated and removed from the kernel release ?
