dj2kenne wrote on Tuesday, December 06, 2016:
In the CCS/ARM_Cortex-R5 port (used for TI Hercules RM57 safety processors, in particular) the portSET_INTERRUPT_MASK_FROM_ISR() macro is not defined, so it ends up being stubbed out.
This macro is used from the various …FromISR() functions to disable interrupts.
Unfortunately, the …FromISR() functions CAN be called from Tasks. In particular, FreeRTOS+UDP does this all the time (see xProcessReceivedUDPPacket() in FreeRTOS_Sockets.c, for example). The net result is that interrupts are not disabled during various OS critical sections inside these …FromISR() functions, and internal OS structures end up getting mangled if interrupts occur at the wrong times.
There seems to be an impression (perpetuated in posts on this forum, even, see https://sourceforge.net/p/freertos/discussion/382005/thread/c7121eea/?limit=25#2487) that this macro can be stubbed out if the port does not support nested interrupts. This is simply untrue.
I have a proposed fix if that would be helpful. I want to make sure that the intent is understood first.
