magnuskriel wrote on Tuesday, March 27, 2012:
I am trying to implement the dsPIC port of FreeRTOS. I am using the PIC32 edition Realtime Kernel reference manual as it was the closest to dsPIC33. In the manual they show code listings of interrupts that call the portSAVE_CONTEXT and portRESTORE_CONTEXT upon entering and exiting the ISR respectively. In the demo code for the dsPIC33 the portSAVE_CONTEXT and portRESTORE_CONTEXT are not called in the USART interrupts. The demo code does make use of the taskYield however.
Why is portSAVE_CONTEXT and portRESTORE_CONTEXT not used in the dsPIC33 and other MPU demos and why is it used in other cases
When do I need to use it?
Thanks in advance
