Portmacro.h compile error in 9.0.0
groger57 wrote on Thursday, August 04, 2016:
Hello:
I just switched over my code from 8.0.0 (compiled OK) to 9.0.0, where I am getting an error that I don’t understand from the line number it’s reporting.
I am using the ARM_CM3 version of portmacro.h in IAR EWARM. The compile error says this:
Error[Pe018]: expected a “)” C:\Users\grr\Documents\IAR Embedded Workbench\FreeRTOSv9.0.0\FreeRTOS\Source\portable\IAR\ARM_CM3\portmacro.h 144
I don’t see anything wrong with that line, and the corresponding define in the FreeRTOS config looks OK, and it is compiling with 8.0.0.
Thanks for the assistance…
rtel wrote on Thursday, August 04, 2016:
Line 144 is:
#if( configMAX_PRIORITIES > 32 )
so I’m going to guess the problem is with the definition of
configMAX_PRIORITIES in your FreeRTOSConfig.h file.
Ensure configMAX_PRIORITIES is just a number, without any casts.
Removing the cast fixed it. Worked Ok in 8.0.0. Thanks for your help !
.#define configMAX_PRIORITIES ( ( unsigned portBASE_TYPE ) 5 )
Gary
