system
(system)
March 21, 2008, 2:56pm
1
libsen wrote on Friday, March 21, 2008 :
I want to port the demoproject made for PIC33FJ256GP710 to another PIC33F, say PIC33FJ256GP510.
If I make a "Bulid All" on the original project, there are no errors. MPLAB is V8.02 + C30 newest release.
To port this project to PIC33FJ256GP510, I change this 3 places in the project:
1. In menu "Configure" + "Select" the device PIC33FJ256GP510 i selected.
2. In file FreeRTOSConfig.h edit the include line to be: #include <p33FJ256GP510.h>
3. Remove the original linker script file (p33FJ256GP710.gld) and add new linker script file p33FJ256GP510.gld
Now, if you build the project following message come up:
In file included from …/Demo/dsPIC_MPLAB/FreeRTOSConfig.h:46,
from ./include/FreeRTOS.h:56,
from list.c:92:
c:/programmer/microchip/mplab c30/bin/…/support/h/p33FJ256GP710.h:8:2: error: #error "Include file does not match processor setting"
Halting build on first failure as requested.
What is the reason for this?
Thanks in advance for any hint / advices.
rtel
(Richard Barry)
March 21, 2008, 3:14pm
2
rtel wrote on Friday, March 21, 2008 :
When you attempt to build, take a look at the command line being used (visible in the Output) window. One of the options will be -mcpu= followed by the processor model. Does it say -mcpu=PIC33FJ256GP510?
system
(system)
March 21, 2008, 3:24pm
3
Yes, the command line shows the correct processor. Look here:
Clean: Done.
Executing: "C:\Programmer\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256GP510 -x c -c "main.c" -o"main.o" -I"." -I".\include" -I"…\include" -I"…\…\include" -I"…\…\…\include" -I"…\…\Source\include" -I"…\…\…\Source\include" -I"…\Demo\dsPIC_MPLAB" -I"…\…\…\Demo\dsPIC_MPLAB" -I"…\…\…\…\Demo\dsPIC_MPLAB" -I".\FileSystem" -I"…\Common\include" -I"…\…\Common\include" -D__DEBUG -g -Wall -DMPLAB_DSPIC_PORT -O2 -fomit-frame-pointer -fno-schedule-insns -fno-schedule-insns2
Executing: "C:\Programmer\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=33FJ256GP510 -x c -c "list.c" -o"list.o" -I"." -I".\include" -I"…\include" -I"…\…\include" -I"…\…\…\include" -I"…\…\Source\include" -I"…\…\…\Source\include" -I"…\Demo\dsPIC_MPLAB" -I"…\…\…\Demo\dsPIC_MPLAB" -I"…\…\…\…\Demo\dsPIC_MPLAB" -I".\FileSystem" -I"…\Common\include" -I"…\…\Common\include" -D__DEBUG -g -Wall -DMPLAB_DSPIC_PORT -O2 -fomit-frame-pointer -fno-schedule-insns -fno-schedule-insns2
from list.c:92:
rtel
(Richard Barry)
March 21, 2008, 3:35pm
4
You could try replacing the #include within FreeRTOSConfig.h to include "p33fxxxx.h" instead.
system
(system)
March 21, 2008, 4:02pm
5
Thanks for this hint, however the result is exact the same
rtel
(Richard Barry)
March 21, 2008, 4:31pm
6
I just tried exactly the steps from your first post, ‘cleaned’ the project (did you do that?), then did a ‘build all’. Here is my output:
Executing: “C:\Devtools\Microchip\MPLAB C30\bin\pic30-gcc.exe” -mcpu=33FJ256GP510 -x c -c “main.c” -o"main.o" -I"." -I".\include" -I"…\include" -I"…\…\include" -I"…\…\…\include" -I"…\…\Source\include" -I"…\…\…\Source\include" -I"…\Demo\PIC24_MPLAB" -I"…\…\…\Demo\PIC24_MPLAB" -I"…\…\…\…\Demo\PIC24_MPLAB" -I".\FileSystem" -I"…\Common\include" -I"…\…\Common\include" -g -Wall -DMPLAB_PIC24_PORT -mlarge-code -fomit-frame-pointer -fno-schedule-insns -fno-schedule-insns2
Executing: “C:\Devtools\Microchip\MPLAB C30\bin\pic30-gcc.exe” -mcpu=33FJ256GP510 -x c -c “list.c” -o"list.o" -I"." -I".\include" -I"…\include" -I"…\…\include" -I"…\…\…\include" -I"…\…\Source\include" -I"…\…\…\Source\include" -I"…\Demo\PIC24_MPLAB" -I"…\…\…\Demo\PIC24_MPLAB" -I"…\…\…\…\Demo\PIC24_MPLAB" -I".\FileSystem" -I"…\Common\include" -I"…\…\Common\include" -g -Wall -DMPLAB_PIC24_PORT -mlarge-code -fomit-frame-pointer -fno-schedule-insns -fno-schedule-insns2
Executing: “C:\Devtools\Microchip\MPLAB C30\bin\pic30-gcc.exe” -mcpu=33FJ256GP510 -x c -c “queue.c” -o"queue.o" -I"." -I".\include" -I"…\include" -I"…\…\include" -I"…\…\…\include" -I"…\…\Source\include" -I"…\…\…\Source\include" -I"…\Demo\PIC24_MPLAB" -I"…\…\…\Demo\PIC24_MPLAB" -I"…\…\…\…\Demo\PIC24_MPLAB" -I".\FileSystem" -I"…\Common\include" -I"…\…\Common\include" -g -Wall -DMPLAB_PIC24_PORT -mlarge-code -fomit-frame-pointer -fno-schedule-insns -fno-schedule-insns2
Executing: “C:\Devtools\Microchip\MPLAB C30\bin\pic30-gcc.exe” -mcpu=33FJ256GP510 -x c -c “tasks.c” -o"tasks.o" -I"." -I".\include" -I"…\include" -I"…\…\include" -I"…\…\…\include" -I"…\…\Source\include" -I"…\…\…\Source\include" -I"…\Demo\PIC24_MPLAB" -I"…\…\…\Demo\PIC24_MPLAB" -I"…\…\…\…\Demo\PIC24_MPLAB" -I".\FileSystem" -I"…\Common\include" -I"…\…\Common\include" -g -Wall -DMPLAB_PIC24_PORT -mlarge-code -fomit-frame-pointer -fno-schedule-insns -fno-schedule-insns2
Executing: “C:\Devtools\Microchip\MPLAB C30\bin\pic30-gcc.exe” -mcpu=33FJ256GP510 -x c -c “port.c” -o"port.o" -I"." -I".\include" -I"…\include" -I"…\…\include" -I"…\…\…\include" -I"…\…\Source\include" -I"…\…\…\Source\include" -I"…\Demo\PIC24_MPLAB" -I"…\…\…\Demo\PIC24_MPLAB" -I"…\…\…\…\Demo\PIC24_MPLAB" -I".\FileSystem" -I"…\Common\include" -I"…\…\Common\include" -g -Wall -DMPLAB_PIC24_PORT -mlarge-code -fomit-frame-pointer -fno-schedule-insns -fno-schedule-insns2
Executing: “C:\Devtools\Microchip\MPLAB C30\bin\pic30-gcc.exe” -mcpu=33FJ256GP510 -x c -c “heap_1.c” -o"heap_1.o" -I"." -I".\include" -I"…\include" -I"…\…\include" -I"…\…\…\include" -I"…\…\Source\include" -I"…\…\…\Source\include" -I"…\Demo\PIC24_MPLAB" -I"…\…\…\Demo\PIC24_MPLAB" -I"…\…\…\…\Demo\PIC24_MPLAB" -I".\FileSystem" -I"…\Common\include" -I"…\…\Common\include" -g -Wall -DMPLAB_PIC24_PORT -mlarge-code -fomit-frame-pointer -fno-schedule-insns -fno-schedule-insns2
Executing: “C:\Devtools\Microchip\MPLAB C30\bin\pic30-gcc.exe” -mcpu=33FJ256GP510 -x c -c “BlockQ.c” -o"BlockQ.o" -I"." -I".\include" -I"…\include" -I"…\…\include" -I"…\…\…\include" -I"…\…\Source\include" -I"…\…\…\Source\include" -I"…\Demo\PIC24_MPLAB" -I"…\…\…\Demo\PIC24_MPLAB" -I"…\…\…\…\Demo\PIC24_MPLAB" -I".\FileSystem" -I"…\Common\include" -I"…\…\Common\include" -g -Wall -DMPLAB_PIC24_PORT -mlarge-code -fomit-frame-pointer -fno-schedule-insns -fno-schedule-insns2
Executing: “C:\Devtools\Microchip\MPLAB C30\bin\pic30-gcc.exe” -mcpu=33FJ256GP510 -x c -c “croutine.c” -o"croutine.o" -I"." -I".\include" -I"…\include" -I"…\…\include" -I"…\…\…\include" -I"…\…\Source\include" -I"…\…\…\Source\include" -I"…\Demo\PIC24_MPLAB" -I"…\…\…\Demo\PIC24_MPLAB" -I"…\…\…\…\Demo\PIC24_MPLAB" -I".\FileSystem" -I"…\Common\include" -I"…\…\Common\include" -g -Wall -DMPLAB_PIC24_PORT -mlarge-code -fomit-frame-pointer -fno-schedule-insns -fno-schedule-insns2
Executing: “C:\Devtools\Microchip\MPLAB C30\bin\pic30-gcc.exe” -mcpu=33FJ256GP510 -x c -c “crflash.c” -o"crflash.o" -I"." -I".\include" -I"…\include" -I"…\…\include" -I"…\…\…\include" -I"…\…\Source\include" -I"…\…\…\Source\include" -I"…\Demo\PIC24_MPLAB" -I"…\…\…\Demo\PIC24_MPLAB" -I"…\…\…\…\Demo\PIC24_MPLAB" -I".\FileSystem" -I"…\Common\include" -I"…\…\Common\include" -g -Wall -DMPLAB_PIC24_PORT -mlarge-code -fomit-frame-pointer -fno-schedule-insns -fno-schedule-insns2
Executing: “C:\Devtools\Microchip\MPLAB C30\bin\pic30-gcc.exe” -mcpu=33FJ256GP510 -x c -c “ParTest.c” -o"ParTest.o" -I"." -I".\include" -I"…\include" -I"…\…\include" -I"…\…\…\include" -I"…\…\Source\include" -I"…\…\…\Source\include" -I"…\Demo\PIC24_MPLAB" -I"…\…\…\Demo\PIC24_MPLAB" -I"…\…\…\…\Demo\PIC24_MPLAB" -I".\FileSystem" -I"…\Common\include" -I"…\…\Common\include" -g -Wall -DMPLAB_PIC24_PORT -mlarge-code -fomit-frame-pointer -fno-schedule-insns -fno-schedule-insns2
Executing: “C:\Devtools\Microchip\MPLAB C30\bin\pic30-gcc.exe” -mcpu=33FJ256GP510 -x c -c “blocktim.c” -o"blocktim.o" -I"." -I".\include" -I"…\include" -I"…\…\include" -I"…\…\…\include" -I"…\…\Source\include" -I"…\…\…\Source\include" -I"…\Demo\PIC24_MPLAB" -I"…\…\…\Demo\PIC24_MPLAB" -I"…\…\…\…\Demo\PIC24_MPLAB" -I".\FileSystem" -I"…\Common\include" -I"…\…\Common\include" -g -Wall -DMPLAB_PIC24_PORT -mlarge-code -fomit-frame-pointer -fno-schedule-insns -fno-schedule-insns2
Executing: “C:\Devtools\Microchip\MPLAB C30\bin\pic30-gcc.exe” -mcpu=33FJ256GP510 -x c -c “integer.c” -o"integer.o" -I"." -I".\include" -I"…\include" -I"…\…\include" -I"…\…\…\include" -I"…\…\Source\include" -I"…\…\…\Source\include" -I"…\Demo\PIC24_MPLAB" -I"…\…\…\Demo\PIC24_MPLAB" -I"…\…\…\…\Demo\PIC24_MPLAB" -I".\FileSystem" -I"…\Common\include" -I"…\…\Common\include" -g -Wall -DMPLAB_PIC24_PORT -mlarge-code -fomit-frame-pointer -fno-schedule-insns -fno-schedule-insns2
Executing: “C:\Devtools\Microchip\MPLAB C30\bin\pic30-gcc.exe” -mcpu=33FJ256GP510 -x c -c “comtest.c” -o"comtest.o" -I"." -I".\include" -I"…\include" -I"…\…\include" -I"…\…\…\include" -I"…\…\Source\include" -I"…\…\…\Source\include" -I"…\Demo\PIC24_MPLAB" -I"…\…\…\Demo\PIC24_MPLAB" -I"…\…\…\…\Demo\PIC24_MPLAB" -I".\FileSystem" -I"…\Common\include" -I"…\…\Common\include" -g -Wall -DMPLAB_PIC24_PORT -mlarge-code -fomit-frame-pointer -fno-schedule-insns -fno-schedule-insns2
Executing: “C:\Devtools\Microchip\MPLAB C30\bin\pic30-gcc.exe” -mcpu=33FJ256GP510 -x c -c “serial.c” -o"serial.o" -I"." -I".\include" -I"…\include" -I"…\…\include" -I"…\…\…\include" -I"…\…\Source\include" -I"…\…\…\Source\include" -I"…\Demo\PIC24_MPLAB" -I"…\…\…\Demo\PIC24_MPLAB" -I"…\…\…\…\Demo\PIC24_MPLAB" -I".\FileSystem" -I"…\Common\include" -I"…\…\Common\include" -g -Wall -DMPLAB_PIC24_PORT -mlarge-code -fomit-frame-pointer -fno-schedule-insns -fno-schedule-insns2
serial.c: In function ‘xSerialPortInitMinimal’:
serial.c:103: error: ‘U2MODEBITS’ has no member named ‘RXINV’
BUILD FAILED: Fri Mar 21 16:28:07 2008
So the device does not define ‘U2MODEBITS’, but I don’t get the same error as you.
system
(system)
March 22, 2008, 7:04am
7
libsen wrote on Saturday, March 22, 2008 :
Yes I tried to clean the project, this did not help either.
Do you also use MPLAB 8.02?
system
(system)
March 22, 2008, 7:56am
8
OK, now I finally found out of something.
The path for the original demo project files on my pc is: D:\FreeRTOS\Demo\dsPIC_MPLAB
I copied all the files there to a new folder, say: D:\FreeRTOS\Demo\dsPIC_MPLAB_TEST, and started to work on the project in this folder. This did not work.
Now I just tried to modify the project in the original folder, and here there is no problem. So I guess the problem has something to do with all search and other paths defined in the project. Even, if you just rename the folder to another name and still use the original project for processor PIC33FJ256GP710 it will not work.
So now the problem is isolated to some of the path definitions somewhere.
