sganguly wrote on Tuesday, August 28, 2018:
I want to port FreeRTOS to NXP make LPC1778 (Arm Cortex M3). Can you suggest the closest Demo Application to start with?
westmorelandeng wrote on Tuesday, August 28, 2018:
Hello Supriyo,
I think the LPC1768 port would be good to start with - you can look under
…FreeRTOS_SVN\freertos\trunk\FreeRTOS\Demo
And you should see 3 Cortex_LPC1768 ports - should be enough to get started with and adapting the LPC1768 should be fairly straightforward.
Good Luck,
John W.
