kenmosher wrote on Friday, October 10, 2014:
Hopefully this is a “forehead slap” type of question…
We’ve been moving an ARM7 project using FreeRTOS 5.4.0 that was previously on CrossWorks 2.0 to a new repository and build environment using CrossWorks 2.1.1 starting with a new Project template and imported everything.
We’ve sorted through a bunch of stuff with the includes for the project, setting ANSI checking to NO and arm-unknown-elf for the GCC Target.  All compiles and then when it gets to heap_2.c in the linker we get
#“error: portBYTE_ALIGNMENT_MASK undeclared (first use in this function)”
I can’t for the life of me find where portBYTE_ALIGNMENT_MASK is declared, so I’m not sure if we are missing something or if I still have a path that’s not included in the project (most likely). I have found portBYTE_ALIGNMENT in portmacro.h (which makes perfect sense).
Once I get this to build cleanly and test out on the target, then I can introduce the next level of the port to get it up to a later version of FreeRTOS.
Thanks for any insights!
