rnbrock wrote on Thursday, April 16, 2009:
My target is an ATMega323 and I am working on a simple example where I set/clear bits on PORTA from within a spawned task just to verify the task is running. The xTaskCreate call appears to work based on the return value, but PORTA does not get updated. If I move the PORTA manipulation outside of the task, it works fine. Do I need to do something specific to enable port manipulation from within a task?
Thanks,
Robert
