bullitt168 wrote on Thursday, August 11, 2005:
Hello! Has anyone ported the freeRTOS to a TI MSP430F169 sucessfully and would provide his modified files? The Port for the MSP430F149 is not directly usable because of the external oszillator, which is used on the EasyWeb-Demoboard.
Thank you very much in advance,
Bastian!
nobody wrote on Thursday, August 11, 2005:
What is different about this part that means it will not work with FreeRTOS? It has the same CPU core?
FreeRTOS uses a timer to generate the RTOS tick. If it does not have the same timer configuration then maybe you have to use a different timer?
