nobody wrote on Wednesday, February 22, 2006:
I’m trying to port the freertos to str ARM 7 on RIDE.
I took the one with IAR and did some changes for being compile with RIDE and I force the task to run in ARM mode because in thumb mode it is not working properly.
port.c : #define portINITIAL_SPSR 0x1f
In this case task are working properly, TaskSuspend-TaskResume is working properly, queue is working properly but vTaskDelayUntil is not working properly and I can’t understand why.
Could you explain changes that I must dio to use properly the freertos in thumb mode or how to port to ride.
Thanks a lot
