Hi ,
I’m porting the ota demo from a reference on stm32h743 to stm32f767 on the nucleo board9nucleo-f767zi). after the ota image downloaded and device reset, the bootloader find a new image, swap to bank 0(main application bank), set the image flag as pending commit, then jump to application code(ota demo)to communicate with IoT Core to validate the new image. but current porting is stuck here then reset with bootloader again, then the bootloader treat pending commit flag as invalid image so the ota process fail.
I checked the binary, the application code do stuck after reset, but the behavior is 4 times of reset, only the first 2 times got stuck. I think this is the root cause of why ota process failed as when it can not jump to application, the watchdog expired and reset with bootloader again.
any hints to potential root cause of this application jump issue ?
attached the log of h7(base reference) and f7(working in progress)behavior fyi.
thanks
