ddement wrote on Wednesday, September 23, 2009:
I’m trying to clone the port.c from the AtmelSAM9XE folder as the basis for a SAM9260 system, but built with an older (4.20) IAR compiler.
I look at the prvSetupTimerInterrupt() code which uses the AIC_ConfigureIT() function to link the PIT interrupt to its handler. The handler is specified as vPortTickISR(). The comments in ISR code says it is called by a wrapper, but it sure doesn’t look like that is how the AIC is set up. And I can’t find a tick wrapper .s79 source file anywhere.
Can anyone please clarify - is this really correct?
Thank you.
