Hi all
My current code looks like:
void mqttOnDisconnect()
disconnected = true;
IotMqtt_Connect(...)
IotMqtt_TimedSubscribe(...)
OTA_AgentInit(...)
while(!disconnected)
OTA_AgentShutdown(...)
I pull the ethernet plug and get mqttOnDisconnect(KEEP_ALIVE_TIMEOUT) as expected.
Problem here is that by the time OTA_AgentShutdown() is called the MQTT connection is aleady closed and _IotMqtt_RemoveSubscriptionByTopicFilter() hangs on ASSERT (contextIndex = -1).
I then tried moving OTA_AgentShutdown() to mqttOnDisconnect(), but it looks as if OTA spins off a job that ends up calling _IotMqtt_RemoveSubscriptionByTopicFilter() after OTA_AgentShutdown() returns (leading to mqttOnDisconnect() returning leading to MQTT closing the connection).
So, when do I call OTA_AgentShutdown() or don’t I need to do that (i.e. does MQTT clean that up properly?)
Or do I need to wait for OTA to shutdown in mqttOnDisconnect? This feels… wrong somehow
Thanks
W
