hudson2009 wrote on Wednesday, July 15, 2009:
I am working on AT91SAM7x and FreeRTOS5.0.4
Trying to read 100ms pulse using one of the PIOB and using the configuration below,
but alway got interrupt on both pulse in and pulse oput (alway reading 2 interrupt for single pulse)
Another thing is, I try to set the intrurrpt as positive edge trigger on AIC_SMR, but with the configuration, the intrruprt is not fire at all.
can any one help?
my setup code as follow:
// ISR setup
void Init_PIOB_isr(void)
extern void (vPIOB_ISR_Wrapper) ( void );
//Pulse_Count = 0;
Count_Ctrl.Count_On = COUNT_OFF;
portENTER_CRITICAL();
// Setup PIO
AT91C_BASE_PIOB->PIO_PER = AT91C_PIO_PB7; // Set in PIO mode.
AT91C_BASE_PIOB->PIO_ODR = AT91C_PIO_PB7; // Set to Input only (disable output).
AT91C_BASE_PIOB->PIO_IFER = AT91C_PIO_PB7; // input glith filter
//AT91C_BASE_PIOB->PIO_IER = AT91C_PIO_PB7; // Enable input change interupt.
AT91C_BASE_PIOB->PIO_CODR = AT91C_PIO_PB7; // clear
AT91C_BASE_PIOB->PIO_PPUDR = AT91C_PIO_PB7; // Pull up disable
// Config PMC
AT91C_BASE_PMC->PMC_PCER = 1 << AT91C_ID_PIOB;
// Setup ISR.
AT91C_BASE_AIC->AIC_IDCR = 1 << AT91C_ID_PIOB;// Disable the interrupt first
// Configure mode and handler
//AT91C_BASE_AIC->AIC_SMR[AT91C_ID_PIOB] = AT91C_AIC_PRIOR_HIGHEST | AT91C_AIC_SRCTYPE_POSITIVE_EDGE;
AT91C_BASE_AIC->AIC_SMR[AT91C_ID_PIOB] = AT91C_AIC_PRIOR_HIGHEST | AT91C_AIC_SRCTYPE_INT_HIGH_LEVEL;
AT91C_BASE_AIC->AIC_SVR[AT91C_ID_PIOB] = (unsigned int) vPIOB_ISR_Wrapper;
// Clear interrupt
AT91C_BASE_AIC->AIC_ICCR = 1 << AT91C_ID_PIOB;
// Enable interupt.
AT91C_BASE_AIC->AIC_IECR = 1 << AT91C_ID_PIOB;
portEXIT_CRITICAL();
// Interrupt Handler
void vPIOB_ISR_Wrapper( void )__attribute__ ((naked));
void vPIOB_ISR_Handler( void );
/* Save the context of the interrupted task. */
portSAVE_CONTEXT();
/* Call the handler.
to ensure the correct stack frame is set up. */
vPIOB_ISR_Handler();
/* Restore the context of whichever task is going to run next. */
portRESTORE_CONTEXT();
unsigned long status;
// Diabale interrupt
// Clear interupt.
status = (AT91C_BASE_PIOB -> PIO_ISR);
status &= (AT91C_BASE_PIOB -> PIO_IMR);
if (status & AT91C_PIO_PB7)
Pulse_Count++;
// Enable Interupt.
AT91C_BASE_AIC->AIC_EOICR = 0;
