Because I am working on a product that will use a PIC32MX460 I am using the PIC32 starter kit version 1 instead of version 2. Other then the error “main.c:44: error: unknown configuration setting: ‘FSRSSEL’” is there any other known issues?
The ports for the original and new parts are identical. The FSRSSEL bit is only applicable to the new parts, so you are right to remove it. You may also have to change the memory map if the amount of Flash or RAM is different.
Thanks. I have used FreeRTOS with a AVR part but this is the first PIC32 project I have done. Nothing like jumping into the deep end of the pool. Are the sample project using custom linker files? So far just changing the selected device appear to be working.
