krikke999 wrote on Friday, July 22, 2011:
prototype of the task looks like this:
void vTaskCPanel(void *pvParameters)
char action;
portBASE_TYPE xStatus;
char isBusy = 0;
TaskType event;
unsigned int sensorValue;
datacontainer data;
pin_location motor;
pin_location sensor;
motor.portId1 = IOPORT_F;
motor.bit1 = BIT_0;
motor.portId2 = IOPORT_F;
motor.bit2 = BIT_1;
sensor.portId1 = IOPORT_B;
sensor.bit1 = BIT_15;
sensor.portId2 = IOPORT_D;
sensor.bit2 = BIT_4;
data.motor = motor;
data.sensor = sensor;
for(;
// wait for action queue, to be filled by vTaskEthListener
if (isBusy == 0)
xStatus = xQueueReceive(xQueueCPanel, &action, portMAX_DELAY);
if ( xStatus == pdPASS)
isBusy = 1;
event = Start;
// TODO: send error
// handle action
switch (action)
case 0:
switch (event)
case Start:
vTaskSuspendAll();
PORTSetBits(IOPORT_F, BIT_0);
PORTClearBits(IOPORT_F, BIT_1);
xTaskResumeAll();
event = Running;
break;
case Running:
vTaskSuspendAll();
sensorValue = PORTReadBits(IOPORT_B, BIT_15);
if (sensorValue == 0)
InternalMotorStop(&motor);
event = Stopped;
xTaskResumeAll();
break;
case Stopped:
isBusy = 0;
break;
// TODO: read core timer to check for sensor errors
// Delay task
vTaskDelay(100/portTICK_RATE_MS);
break;
case 1:
switch (event)
case Start:
vTaskSuspendAll();
PORTSetBits(motor.portId2, motor.bit2);
PORTClearBits(motor.portId1, motor.bit1);
xTaskResumeAll();
event = Running;
break;
case Running:
vTaskSuspendAll();
sensorValue = PORTReadBits(sensor.portId2, sensor.bit2);
event = Stopped;
xTaskResumeAll();
break;
case Stopped:
isBusy = 0;
break;
// Delay task
break;
