randers wrote on Saturday, January 17, 2009:
I have recognized the following certain behavior in the PIC32-demo-project:
The original project works with 80Mhz-SysCLK & 40MHz-PBCLK.
This is realized by the following lines in main.c:
#pragma config FPLLMUL = MUL_20, FPLLIDIV = DIV_2, FPLLODIV = DIV_1, FWDTEN = OFF
#pragma config POSCMOD = HS, FNOSC = PRIPLL, FPBDIV = DIV_2
// SysCLK = 8 / FPLLIDIV * FPLLMUL / FPLLODIV
The compiler itself gets this information by the following lines in FreeRTOSConfig.h:
#define configCPU_CLOCK_HZ ( ( unsigned portLONG ) 80000000UL )
#define configPERIPHERAL_CLOCK_HZ ( ( unsigned portLONG ) 40000000UL )
I lowered the CPU-Clock by setting FPLLODIV = DIV_2 // DIV4, DIV8, …
(and customizing FreeRTOSConfig.h)
The PB-Clock is in each case half of the CPU-Clock.
The demo works with 80/40MHz (original settings). It works with 40/20MHz too.
But with 20/10MHz and 10/5MHz failures are reported via LCD-display:
"Error: Gen Q" , "Error: Blck time" …
Is there anything known?
ralf
